[petsc-dev] mvapich and petsc-dev
Satish Balay
balay at mcs.anl.gov
Thu Apr 14 11:11:35 CDT 2011
Can you run the mvapich codde with -vecscatter_alltoall and see if
it goes through?
satish
On Thu, 14 Apr 2011, Ethan Coon wrote:
> I'm a bit grasping at straws here, because I'm completely stymied, so
> please bear with me.
> I'm running a program in two locations -- on local workstations with
> mpich2 and on a supercomputer with mvapich.
> On the workstation, the program runs, in all cases I've tested,
> including 8 processes (the number of cores), and up to 64 processes
> (multiple procs per core).
> On the supercomputer, it runs on 16 cores (one full node). With 64
> cores, it seg-faults and core dumps many timesteps in to the
> simulation.
> Using a debugger, a debug-enabled petsc-dev, but with no access to
> debugging symbols in the mvapich installation, I've looked at the core.
> It appears to dump during VecScatterBegin_1 (within a DMDALocalToLocal()
> with xin = xout). The Vec I pass in as both input and output appears
> normal.
> The stack looks something like:
> MPIR_HBT_lookup, FP=7fff1010f740
> PMPI_Attr_get, FP=7fff1010f780
> PetscCommDuplicate, FP=7fff1010f7d0
> PetscViewerASCIIGetStdout, FP=7fff1010f800
> PETSC_VIEWER_STDOUT_, FP=7fff1010f820
> PetscDefaultSignalHandler, FP=7fff1010fa70
> PetscSignalHandler_Private, FP=7fff1010fa90
> **** Signal Stack Frame ******************
> MPID_IsendContig, FP=7fff1010ff20
> MPID_IsendDatatype, FP=7fff1010ffa0
> PMPI_Start, FP=7fff1010fff0
> VecScatterBegin_1, FP=7fff10110080
> VecScatterBegin, FP=7fff101100e0
> DMDALocalToLocalBegin, FP=7fff10110120
> dmdalocaltolocalbegin_, FP=7fff10110160
> Has anyone run into anything like this before? I have no clue even how
> to proceed, and I doubt this is a PETSc problem, but I figured you guys
> might have enough experience in these types of issues to know where to
> look from here...
> Thanks,
> Ethan
