[petsc-dev] Preconditioner for Schur complement (pcfieldsplit)
    Jed Brown
    jed at 59A2.org
    Thu Apr  7 02:57:12 CDT 2011
On Thu, Apr 7, 2011 at 09:42, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> The problem is that the data field (vec->data) of the nested vectors is
> empty. I created the nested vectors exactly in the same way as in
> /src/ksp/ksp/examples/tests/ex22.c. When I would make a VecGetArray(myvec,
> &vecptr) on a nested vector myvec, than vecptr is not a vailde pointer.
Indeed, this is why this test uses no preconditioner. I do not recommend
VecNest for general use, there are many places where it will be problematic.
So go ahead and use the MatNest, but just create a normal Vec.
Eventually, I want to remove the explicit scatters in the PCFieldSplit
implementation in favor of VecGetSubVector(). When that is done, VecNest
will provide a way to eliminate some copies (at the expense of memory layout
so it will still not always be faster), but its use should still remain
hidden from user code. Don't bother with it now.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110407/44dfd7df/attachment.html>
