[petsc-dev] Preconditioner for Schur complement (pcfieldsplit)
Thomas Witkowski thomas.witkowski at tu-dresden.de
Wed Apr 6 04:36:53 CDT 2011
Jed Brown wrote:
> On Wed, Apr 6, 2011 at 09:34, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> <mailto:thomas.witkowski at tu-dresden.de>> wrote:
>     I have not a very good overview of PETSc's internal matters, but
>     wouldn't be it correct that MatGetBlockSize returns the number of
>     nested matrices of a MatNest?
> No, and it would not make sense to do so because that is semantically
> different information.
> We can add support for automatically detecting splits when MatNest is
> used, but it really is better to set the splits using
> PCFieldSplitSetIS() or by using DMComposite because then it will do
> the correct thing regardless of whether MatNest is used underneath.
This brings me back to the starting point of my current problem: how to
set splits for MatNest correctly? PCFieldSplitSetFields seems not to
work in my case. When I want to make use of PCFieldSplitSetIS for
splitting MatNest, which indices should I provide? The MatNest I've
created consists of the to main diagonal blocks with indices 0 to n and
0 to m. I'm not sure which index sets must be provided for
PCFieldSplitSetIS.
Thomas
