[petsc-dev] buildsystem package dependencies
Tue Apr 5 12:23:23 CDT 2011
On Tue, 5 Apr 2011, Lisandro Dalcin wrote:
> On 5 April 2011 13:20, Satish Balay <balay at mcs.anl.gov> wrote:
> > Not sure I understand. If I say 'mpi depends on mpe' - then the link line is:
> Sorry, I was thinking in terms of shared libraries.
> > -lhypre -lmpi -lmpe
> > But thats incorrect usage - and not what I want.. The correct usage is:
> > -lhypre -lmpe -lmpi
> > The issue comes up with -llmpe - which traps MPI_xx functions - and does some
> > logging - and then calls MPI_xx functions from -lmpi. i.e usage is:
> If you are going to use MPE  from MPICH2, "mpicc -mpe=mpilog" does the
> right thing:
> $ mpicc -mpe=mpilog -LLIBDIR -lLIBNAME -link_info
> gcc -I/usr/include/mpich2-i386 -m32 -O2 -Wl,-z,noexecstack
> -Wl,--export-dynamic -LLIBDIR -lLIBNAME -I/usr/include/mpich2-i386
> -L/usr/lib/mpich2/lib -L/usr/lib/mpich2/lib -L/usr/lib/mpich2/lib
> -llmpe -lmpe -lmpich -lopa -lpthread -lrt
I guess I'll just leave it at that.. [i.e Its users responsibility to
use "mpicc -mpe=mpilog" if they want to log MPI messages.]
Currently configure supports --with-mpe=1 or --download-mpe=1. This
behaves as any other package. wrt build/usage. If you run 'ex2
-log_mpe' - you get a ex2.clog with all petsc events logged. ./ex2
behaves as before.
But once you want to log petsc events + MPI messages - then it gets
complicated. [thats when MPE becomes MPI replacement - as Matt says].
I was trying to see if there is a easy way to fit petsc+mpi logging in
the current 'package' model. But looks like its easier to say:
Logging PETSc events? use --with-mpe=1 or --download-mpe=1 [and run
with 'ex2 -log_mpe']
Logging MPI calls?  build PETSc with "mpicc -mpe=mpilog" and "mpif90
-mpe=mpilog" or equivalent wrappers - and run as 'ex2' [it always
creates a logfile]
Logging Both PETSc events and MPI calls? build PETSc with "mpicc
-mpe=mpilog" and "mpif90 -mpe=mpilog" --with-mpe=1 ['ex2' creates MPI
only log, while 'ex2 -log_mpe' will crate petsc+mpi log].
[I was hoping to simplify the 3rd part as: build PETSc with
--with-mpe=1 or --download-mpe=1 and --with-mpe-enalbe-mpilog=1, so
that ./'ex2' always creates mpi+petsc log - but that appears to need
merging mpi.py with mpe.py. with mpi.py already being compliated
enought - I' avoid this]
Satish
