[petsc-dev] Compiling C code with C compiler
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Apr  4 21:33:00 CDT 2011
On Apr 4, 2011, at 9:25 PM, Sean Farley wrote:
> What did you expect when you used --with-clanguage=C++ for your buid? Or
> were you misunderstanding what this options means wrt PETSc build?
> I understand what it was trying to do but it is necessary for sieve (especially with certain mesh generators). Why does all of PETSc need to be compiled with C++ in order to use sieve is the real question?
   Since the sieve c++ compiled code uses the C code (like VecXXX) the C++ compiler would have to know that the other parts of C are not compiled with C++. At a minimum you would have to extern c it in the header files other wise the C++ compiled code will call the C routines with name-mangling turned on while the C compiler doesn't know about name mangling and hence would generate routines without name mangling and the c++ code wouldn't find the c routines. In other words, even without issues of struct layouts currently everything in PETSc needs to be built with the same compiler. If sieve was made a completely separate package form PETSc then one could easily arrange things so that sieve compiled with c++ and PETSc with c.
   Why is everyone talking about this unimportant issue when we got serious dlopen() issues to fix?
   Barry
> .c -> compiled with mpicc
> .cxx -> compiled with mpicxx
> Is there something else missing? (Perhaps linking?)
> Sean
