[petsc-dev] Compiling C code with C compiler
Lisandro Dalcin
dalcinl at gmail.com
Mon Apr 4 21:19:14 CDT 2011
On 4 April 2011 23:17, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 4 Apr 2011, Lisandro Dalcin wrote:
>> On 4 April 2011 22:48, Satish Balay <balay at mcs.anl.gov> wrote:
>> > There is clang and clang++ - but still they insist on throwing this warning.
>> > When I invoke clang++ - I want c++. So I'm not sure whats so ambiguous
>> > that they should throw this warning.
>> > And what does this depricate mean? That 'clang++ foo.c' will create C code?
>> > Then why have both clang and clang++?
>> $ file /usr/bin/clang++
>> /usr/bin/clang++: symbolic link to `clang'
>> They should use argv[0] to dispatch C/C++, but it seems this is not the case.
> They do that - but use it to print the warning. [and goes ahead and generates c++ code]
> asterix:/home/balay/junk>clang sizeof.c
> asterix:/home/balay/junk>clang++ sizeof.c
> clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated
Thanks for the clarification, I got it wrong.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
