[petsc-dev] Configure changes
    Matthew Knepley
    knepley at gmail.com
    Tue Sep 28 23:06:14 CDT 2010
What was your blas fix? I am in Frankfurt airport and have trouble looking.
     Matt
On Wed, Sep 29, 2010 at 4:02 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Yes - I don't see them anymore. [I must have forgotten to delete the
> old stuff - before retrying configure..]
> Satish
> On Wed, 29 Sep 2010, Matthew Knepley wrote:
> > They should be gone. I pushed before I left, and checked my run.
> >    Matt
> > On Tue, Sep 28, 2010 at 4:54 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > I still see these aswell..
> > > satish
> > > On Wed, 15 Sep 2010, Barry Smith wrote:
> > > >   Matt,
> > > >     I also get those ugly directories; can you please make them
> > > disappear.
> > > >    Barry
> > > > On Sep 15, 2010, at 10:31 AM, Lisandro Dalcin wrote:
> > > > > On 15 September 2010 11:17, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > >> works for me now. thanks!
> > > > > I've got a bunch of new directories in $PETSC_DIR after running
> > > > > $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py:
> > > > >  drwxr-xr-x.  2 dalcinl users    4096 2010-09-15 11:47
> > > config.compilerFlags
> config.compilers
> config.headers
> config.libraries
> > > config.setCompilers
> > > > >> satish
> > > > >> On Wed, 15 Sep 2010, Matthew Knepley wrote:
> > > > >>> Pushed a fix.
> > > > >>>   Matt
> > > > >>> On Wed, Sep 15, 2010 at 8:31 AM, Satish Balay <balay at mcs.anl.gov
> > > wrote:
> > > > >>>> Thanks. Its much better now. However - I still see 4 dirs per
> run -
> > > > >>>> instead of a single dir.
> > > > >>>> asterix:/home/balay/tmp/petsc-dev>ls -ld /tmp/petsc*
> > > > >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-3t39Wz/
> > > > >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-atP6HX/
> > > > >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-MoSphJ/
> > > > >>>> drwx------. 7 balay balay 4096 Sep 15 08:25 /tmp/petsc-S3q8cO/
> > > > >>>> Satish
> > > > >>>>> I have reorganized the temp dir structure into what we wanted:
> > > > >>>>>   framework has a top-level tmpDir (petsc-foo) per run
> > > > >>>>>   each module has its own dir (petsc-foo/moduleName) below this
> > > > >>>>>   the tmpDir is destryed by framework.cleanup()
> > > > >>>>> and the Windows bug should be fixed.
> > > > >>>>>    Matt
> > > > > Lisandro Dalcin
> > > > > CIMEC (INTEC/CONICET-UNL)
> > > > > Predio CONICET-Santa Fe
> > > > > Colectora RN 168 Km 472, Paraje El Pozo
> > > > > Tel: +54-342-4511594 (ext 1011)
> > > > > Tel/Fax: +54-342-4511169
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100929/b11b5fd2/attachment.html>
