[petsc-dev] [petsc-users] matrix-matrix addition
Boyce Griffith
griffith at cims.nyu.edu
Mon Sep 27 14:00:24 CDT 2010
Hi, Barry et al. --
I'm moving this over to petsc-dev, since that seems like the more
appropriate place.
I'm attaching my stab at implementing MatAXPY for pairs of sequantial
AIJ matrices. I've done only very minimal testing, but it appears to
work for my application.
In the implementation, I create a new matrix W to store the result of
computing a*X+Y. Instead of swapping out the innards of W and Y, my
implementation "returns" the newly allocated matrix W. (I didn't see a
function to swap out matrices. Is there one that could be used here?)
-- Boyce
On 9/27/10 1:06 PM, Barry Smith wrote:
> On Sep 27, 2010, at 12:04 PM, Jed Brown wrote:
>> On Mon, Sep 27, 2010 at 19:01, Barry Smith<bsmith at mcs.anl.gov> wrote:
>>> If you do not merge the column indices from A and B but simply count them all you will get over allocation, at worst a factor of two, though usually it would just be a little.
>> You count the number of *unique* entries. You have two indices that
>> run through the arrays aj and bj, counting duplicates only once. This
>> is easy to do since they are both sorted.
> Yes, sounds like it could work and definitely better than my suggestion.
> Shri, can you try this?
> Barry
>> Jed
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100927/f0bb0be9/attachment.c>
