[petsc-dev] [petsc-maint #53305] configuring petsc with parmetis
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep 22 15:03:43 CDT 2010
   There is a problem with our design.
   If the user has used --download-xxxx and then later deletes everything in $PETSC_ARCH/lib then the next use of --download-xxx will fail because it will find the file
in $PETSC_ARCH/conf/xxxx that indicates the last download succeeded but the libraries won't exist so the check for the packages libraries fails with a not particularlly useful error message.
   How can we fix this? Not just check for $PETSC_ARCH/conf/xxxx but also check for $PETSC_ARCH/lib/libs associated with xxxx before deciding to rebuild? Shoot the user who deletes everything in $PETSC_ARCH/lib?
   Barry
On Sep 22, 2010, at 2:54 PM, Verena Kuhlemann wrote:
> Here is the configure.log that I got when
> --download-parmetis=/home/vkuhlem/research/ParMetis-3.1.1.tar.gz
> was used.
> On Wed, Sep 22, 2010 at 3:25 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  It would be helpful if you mailed us the configure.log file from the case
>> where you tried --download-parmetis and it failed.
>> Barry
>> On Sep 22, 2010, at 2:05 PM, Verena Kuhlemann wrote:
>>> Hello,
>>> I am trying to configure petsc with parmetis. I was able to configure it
>> on
>>> a laptop without any problems.
>>> Now I am trying to install it on a cluster.
>>> I tried using --download-parmetis=1 and
>>> --download-parmetis=whereIsavedparmetis/parmetis.tar.gz
>>> but both didn't work.
>>> Then I installed parmetis and tried:
>> --with-parmetis-dir=whereIsavedparmetis
>>> --with-parmetis-includer=whereIsavedparmetis and
>>> --with-parmetis-lib=whereIsavedparmetis/libparmetis.a
>>> Here I got the error message:
>>>        UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>>> details):
>>> --with-parmetis-dir=/home/vkuhlem/research/ParMetis-3.1.1/ did not work
>>> From what I've read I may have compiled parmetis with a different
>> compiler
>>> than the one I use in petsc. How can I check which one
>>> I used in petsc?
>>> I attached configure.log and hope someone can give me any tips.
>>> Thanks,
>>> Verena
>>> Hello,
>> on a laptop without any problems.
>> details):
>> compiler than the one I use in petsc. How can I check which one
>>> I used in petsc?
>>> Thanks,
>>> Verena
>>> <configure.log>
> Here is the configure.log that I got when --download-parmetis=/home/vkuhlem/research/ParMetis-3.1.1.tar.gz
> was used.
>   It would be helpful if you mailed us the configure.log file from the case where you tried --download-parmetis and it failed.
>  Barry
> > Hello,
> > I am trying to configure petsc with parmetis. I was able to configure it on
> > Then I installed parmetis and tried: --with-parmetis-dir=whereIsavedparmetis
> > details):
> > From what I've read I may have compiled parmetis with a different compiler
> > I used in petsc?
> > Thanks,
> > Verena
> > Hello,
> > I am trying to configure petsc with parmetis. I was able to configure it on a laptop without any problems.
> > I tried using --download-parmetis=1 and --download-parmetis=whereIsavedparmetis/parmetis.tar.gz
> >                                                    --with-parmetis-includer=whereIsavedparmetis and --with-parmetis-lib=whereIsavedparmetis/libparmetis.a
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> > From what I've read I may have compiled parmetis with a different compiler than the one I use in petsc. How can I check which one
> > I used in petsc?
> > Thanks,
> > Verena
> > <configure.log>
> <configure.log>
