[petsc-dev] BuildSystem: PCC=mpicc, CXX and FC
Tue Sep 14 20:54:01 CDT 2010
Do we really want the full path to all compilers? We discussed this before
and did not
do it. Satish, do you remember why?
   Matt
On Tue, Sep 14, 2010 at 8:51 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 14 September 2010 22:26, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Sep 14, 2010, at 8:24 PM, Lisandro Dalcin wrote:
> >> On 14 September 2010 21:55, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>> On Sep 14, 2010, at 6:24 PM, Lisandro Dalcin wrote:
> >>>> 1) If mpicc is in $PATH, then petscvariables will get PCC=mpicc.
> >>>> Perhaps it should get the full path instead?
> >>>> 2) I think CXX and FC variables should be renames to PCXX and PFC. The
> >>>> former names can easily conflict with CXX and FC defined in user
> >>>> makefiles for use with non-MPI sources.
> >>>   Then we should also get rid of CC
> >>>    Essentially you are saying we should remove all "traditional" use of
> these variables from our makefiles? I agree doing that might be a good idea.
> But doesn't it contradict your attempt to try hard to conform to standard
> usage for things?
> >> Sorry, I need a clarification: Could you tell me why PETSc makefiles
> >> uses PCC instead of the "traditional"  CC? Is it just because PCC
> >> could be CC or CXX depending on --with-c-language?
> >   Yes that is one reason and may be the only reason.
> In such case, forget my comments, except for the part of setting
> PCC=/path/to/mpicc (and perhaps the same for CC, CXX, FC if they point
> to MPI compiler wrappers). What do you think about this? Please note
> I'm not objecting the current status, just asking about the full path
> alternative.
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100914/c81e4996/attachment.html>
