[petsc-dev] Handling ESSL + Lapack and PESSL
    Tom Cortese
    tcortese at eecs.utk.edu
    Mon Sep 13 17:04:50 CDT 2010
On the large IBM systems at NAVO, there are some special libraries
installed in addition to ESSL -- I have no idea if this is standard across
AIX machines, or if this is something special that the center staff
installed:
/site/lib: %ls
blas_PW5.a@              libblas_PW5_64.a@        libscalapack_PWR5.a@
blas_PW5_64.a@           libexpat.a               libscalapack_PWR5_64.a@
lapack_PW5.a@            libexpat.la*             libtermcap.a
lapack_PW5_64.a@         liblapack_PW5.a@         tmglib_PW5.a@
libblas_PW5.a@           liblapack_PW5_64.a@      tmglib_PW5_64.a@
/site/lib: %
 	-Tom Cortese
On Mon, 13 Sep 2010, Boyana Norris wrote:
> ESSL does not cover all functions in LAPACK, however (intentionally,
> apparently).
> Boyana
> Boyana Norris, Computer Scientist, Argonne National Laboratory
> norris at mcs.anl.gov, +1.630.252.7908, http://www.mcs.anl.gov/~norris/
> On Sep 13, 2010, at 2:05 PM, Jed Brown wrote:
>> On Mon, 13 Sep 2010 13:55:48 -0500, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>   Does ESSL itself contain "the BLAS"
>> Yes.
>>>   None of this really matters because you are still stuck writing
>>>   the configure test for geev.
>> Yup, we're debugging some SIGILL problem emanating from ESSL or PESSL at
>> the moment.  Will write a test if it turns out to be a configuration
>> that actually works and is desirable.
>> Jed
