[petsc-dev] Handling ESSL + Lapack and PESSL
    Jed Brown
    jed at 59A2.org
    Mon Sep 13 14:05:36 CDT 2010
On Mon, 13 Sep 2010 13:55:48 -0500, Barry Smith <bsmith at mcs.anl.gov> wrote:
>     Does ESSL itself contain "the BLAS"
Yes.
>     None of this really matters because you are still stuck writing
>     the configure test for geev.
Yup, we're debugging some SIGILL problem emanating from ESSL or PESSL at
the moment.  Will write a test if it turns out to be a configuration
that actually works and is desirable.
Jed
