[petsc-dev] [petsc4py] PETSc.Viewer().createHDF5 wipes out existing files
Blaise Bourdin
bourdin at lsu.edu
Thu Sep 9 17:24:01 CDT 2010
> On 9 September 2010 17:40, Blaise Bourdin <bourdin at math.lsu.edu> wrote:
>> Hi,
>> I am trying to do HDF5 IO in petsc4py. I noticed that when I create a viewer using
>> PETSc.Viewer().createHDF5(inputfile,comm= PETSc.COMM_WORLD)
>> the file "outputfile" is wiped out and replaced with a empty hdf5 container, which is bad since I am trying to read forrm it...
>> Unsurprisingly, I have no problems using the longer approach:
>> h5in = PETSc.Viewer().create(PETSc.COMM_WORLD)
>> h5in.setType(PETSc.Viewer.Type.HDF5)
>> h5in.setFileMode(PETSc.Viewer.Mode.READ)
>> h5in.setFileName(inputfile)
>> Is this expected?
> Yes, it is expected. These create() methods default to mode=WRITE.
> What you and others think about this?
I would be in favor of not deleting people's files unless they explicitly ask for it ;) defaulting to append may be the best way, if it is implemented
> To open in READ mode, just do this:
> PETSc.Viewer().createHDF5(inputfile, mode=PETSc.Viewer.Mode.READ,
much nicer, thanks,
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
