[petsc-dev] vtk viewer
Barry Smith
bsmith at mcs.anl.gov
Thu Sep 9 07:48:32 CDT 2010
On Sep 9, 2010, at 5:10 AM, Jed Brown wrote:
> On Thu, 9 Sep 2010 11:38:35 +0200, Matthew Knepley <knepley at gmail.com> wrote:
>> This sounds good. The writers are in the Vec impls, which is probably
>> not optimal since VecGetArray() is a nice interface. I think for
>> modern viewers of Vec, I would put the whole thing in
>> viewer/impls/vtk, since all the data you need from Vec and DA is
>> public.
> I agree that it only needs to use the public API, but it still needs to
> go in the Vec or DM packages respectively, otherwise you pick up reverse
> dependencies from petscsys to petscvec or petscdm. I would put it in
> src/dm/da/src/ where the other DA viewers live.
Yes, but the basic opening of the Viewer likely belongs down in src/sys/viewer/impls/vtk
>> No need to stick stuff underneath. Then you just change VecView() to
>> dispatch to the correct method, and that dispatch has an #ifdef from
>> configure.
> It would be in VecView_MPI_DA().
> There was a thread on this a long time ago, but I think that Some Day
> the viewer dispatch should be migrated to a proper multiple-dispatch
> system so that it can be third-party extensible in both arguments (Vec
> type and Viewer type/format).
Of course.
Barry
> Jed
