[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
    Leo van Kampenhout
    lvankampenhout at gmail.com
    Tue Sep  7 09:31:17 CDT 2010
Thank you Shri, it appears to work correctly now.
Leo
2010/9/7 Shri <abhyshr at mcs.anl.gov>
> I've pushed a fix. Please do hg pull.
> ----- Leo van Kampenhout wrote:
> > Ok I have done that, please have a look. It's a really weird problem.
> 2010/9/6 Barry Smith <bsmith at mcs.anl.gov>
>>    This should not happen. Send the code to petsc-maint at mcs.anl.gov
>> >    Barry
>> On Sep 6, 2010, at 10:54 AM, Leo van Kampenhout wrote:
>> Hello Barry, Matt,
>> About this error I am having:
>> >[2]PETSC ERROR: Nonconforming object sizes!
>> >[2]PETSC ERROR: Mat mat,Vec y: local dim 700536 697068!
>> I am creating my RHS and initial vector from the same DA as the matrix is
>> from (see below). I even tried with setting RHS==1 instead of loading from
>> file, to no avail. I found out the error occurs when #PROC=3,5,7,...,8+ but
>> NOT when #PROC=2,4,8. It might have something to do with differences in
>> partitioning strategies of Mat and Vec? As you know my gridsize has a rather
>> unusual value (number of gridpoints is 2101608).
>> Leo
>>       call DACreateGlobalVector(da,x,ierr)
>>       call VecDuplicate(x,b,ierr)
>>       call DAGetMatrix(da,MATMPIAIJ,A,ierr)
>>       call VecSet(b,one,ierr)
>> >      call KSPCreate(MPI_COMM_WORLD,ksp,ierr)
>>       call KSPSetOperators(ksp,A,A,SAME_NONZERO_PATTERN,ierr)
>>       call KSPSolve(ksp,b,x,ierr)
>> > 2010/9/3 Barry Smith <bsmith at mcs.anl.gov>
>>>     You initial vectors must be created with the same DA that is
>>> associated with the Matrix for the layout to be automatically correct. Use
>>> DACreateGlobalVector() instead of VecCreate(). You may already be doing this
>>> and then the problem is more subtle. Let us know.
>>>    Barry
>>>     Something may be going wrong with the copy header
>>> On Sep 3, 2010, at 11:35 AM, Matthew Knepley wrote:
>>> > On Fri, Sep 3, 2010 at 5:50 PM, Leo van Kampenhout <
>>> lvankampenhout at gmail.com> wrote:
>>>> > Thanks. Following this conversation closely, i have already built
>>>> petsc with --with-debugging=0 and found that then thing work better there.
>>>> Until there is a ultimate fix I'm perfectly happy with that.
>>>> Even on my cluster, I can now run the program for 2,4,8 cores. But there
>>>> is always a catch... with 10 cores, GMRES breaks down! (see below) Sorry to
>>>> bother you with this, it seems unrelated at first sight. Should I issue a
>>>> new thread for this?
>>> This is almost certainly somewhere you are not careful about constructing
>>> a Vec with the proper layout (as the message says). In fact, from the
>>> trace
>>> it looks like the rhs Vec passed in is not compatible with the matrix.
>>>   Matt
>>>> Regards, Leo
>>>> [5]PETSC ERROR: --------------------- Error Message
>>>> > [5]PETSC ERROR: Nonconforming object sizes!
>>>> [5]PETSC ERROR: Mat mat,Vec y: local dim 210161 213282!
>>>> > [5]PETSC ERROR:
>>>> [5]PETSC ERROR: Petsc Development HG revision:
>>>> 6da7d8c5aaa81099861622f4e6bf1087652253a7  HG Date: Fri Sep 03 15:06:40 2010
>>>> +0200
>>>> > [5]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>> [5]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>> [5]PETSC ERROR: See docs/index.html for manual pages.
>>>> [5]PETSC ERROR:
>>>> > [5]PETSC ERROR: ./main on a linux-opt named node164 by s1459295    Fri
>>>> Sep  3 17:44:26 2010
>>>> [5]PETSC ERROR: Libraries linked from
>>>> /home/s1459295/install/petsc-dev/linux-optimized/lib
>>>> [5]PETSC ERROR: Configure run at Fri Sep  3 15:28:20 2010
>>>> > [5]PETSC ERROR: Configure options --with-debugging=0
>>>> [5]PETSC ERROR:
>>>> [5]PETSC ERROR: MatMult() line 1976 in src/mat/interface/matrix.c
>>>> [5]PETSC ERROR: KSPInitialResidual() line 55 in
>>>> src/ksp/ksp/interface/itres.c
>>>> > [5]PETSC ERROR: KSPSolve_GMRES() line 236 in
>>>> src/ksp/ksp/impls/gmres/gmres.c
>>>> [5]PETSC ERROR: KSPSolve() line 427 in src/ksp/ksp/interface/itfunc.c
>>>> 2010/9/3 Jed Brown <jed at 59a2.org>
>>>>> On Fri, 3 Sep 2010 09:15:09 -0600 (GMT-06:00), Shri <
>>>>> abhyshr at mcs.anl.gov> wrote:
>>>>> > > Leo,
>>>>> > >     Jed and I both tried running a MatLoad example (see
>>>>> src/dm/da/examples/tests/ex35.c) with petsc configured in debug mode and had
>>>>> issues running it with your grid size 202 X 102 X 102. This example runs in
>>>>> a reasonable amount of time with the optimized petsc build.
>>>>> > > I suggest running your code on a smaller grid (100 X100 X 100 seems
>>>>> to work fine in the debug mode) for now, get it working and then using the
>>>>> optimized petsc build (--debugging=0) for the large grid size.
>>>>> I wrote an improved sort that doesn't have this bad behavior, but I'm
>>>>> > trying to figure out why the old one is okay in optimized mode.  See
>>>>> > here:
>>>>> >   http://gist.github.com/563948
>>>>> > The MEDIAN macro chooses the median of the first, last, and middle
>>>>> > element in the segment.  Performance looks like
>>>>> >   FAST -O1: 2.0 seconds
>>>>> >   FAST -O0: 5 seconds
>>>>> >   SLOW -O1: 2.3 seconds
>>>>> >   SLOW -O0: more than an hour
>>>>> > SLOW, which is basically the old implementation does a lot of
>>>>> shuffling
>>>>> > with the array and ends up hitting a bad case for quicksort (even
>>>>> with
>>>>> > the median choice).  What I don't understand, is that apparently
>>>>> > building SLOW with -O1 transforms the algorithm into something
>>>>> > asymptotically faster.  The assembly is a few hundred lines, and it's
>>>>> > not obvious to me what this transform would be.
>>>>> > Jed
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100907/450e0a54/attachment.html>
