[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
Shri abhyshr at mcs.anl.gov
Thu Sep 2 12:46:09 CDT 2010
> That code cannot be right. When you copy the App to A it does not have the same nonzero pattern. You should not use a MatCopy() there you should use a MatHeaderMerge() or a MatHeaderReplace() whichever one is right.
Thanks,i was searching for a similar function but did not find it hence used MatCopy. I've fixed this and pushed it.
 > Then try running with a big DA to see how long it takes.   I tried MatLoad on Leo's 3D grid (202 X 102 X 102) but it takes forever to load. Hence, I tried it on a relatively smaller grid (100 X 100 X 100) and here are the log summary numbers that i got.
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s------------------------------------------------------------------------------------------------------------------------
--- Event Stage 0: Main Stage
MatAssemblyBegin       4 1.0 2.6508e-0134.6 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  3  0  0  0  5   3  0  0  0  6     0MatAssemblyEnd         4 1.0 4.2604e-01 1.0 0.00e+00 0.0 1.2e+01 2.0e+04 3.6e+01  9  0 63  1 28   9  0 63  1 38     0MatGetSubMatrice       1 1.0 5.9222e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 13  0  0  0  4  13  0  0  0  5     0MatLoad                       1 1.0 3.2231e+00 1.0 0.00e+00 0.0 1.1e+01 4.0e+06 4.9e+01 70  0 58100 38  70  0 58100 52     0------------------------------------------------------------------------------------------------------------------------
Shri    Barry
On Sep 2, 2010, at 10:17 AM, Leo van Kampenhout wrote:
Hello Shri,
thanks for the fix. The error is now gone but the loading of the Mat takes now infinitely long.. help!!
Leo
2010/9/2 Shri <abhyshr at mcs.anl.gov>
>Pushed. Please let me know if you get any errors.
Shri
----- Barry Smith  wrote:
>  if (size > 1) {     /* change viewer to display matrix in natural ordering */    ierr = MatShellSetOperation(A, MATOP_VIEW, (void (*)(void)) MatView_MPI_DA);CHKERRQ(ierr);
>    /* turn off loading of matrix because loading would require proper permutation I don't feel like writing now */    ierr = MatShellSetOperation(A, MATOP_LOAD, (void (*)(void)) 0);CHKERRQ(ierr);
  Shri,
    Could you please add the support for this? And push to petsc-dev
    Thanks
     Barry
On Sep 1, 2010, at 10:23 AM, Leo van Kampenhout wrote:
Using a DA, of equal size and type as the other one. The curious thing is that there are no problems on a single core run. (but that is not what I want ;)
2010/9/1 Barry Smith <bsmith at mcs.anl.gov>
   Did you get the matrix in the writer code using a DA or some other code that puts the vector from the 2d or 3d problem in the natural ordering on the binary file.
   Barry
On Sep 1, 2010, at 9:55 AM, Leo van Kampenhout wrote:
Hi all,
I'm having trouble with MatLoad on Petsc-Dev. Not sure if this problem also exists in the main PETSc 3.1 since my code won't compile on that.
> The problematic calls are as follows:
      call PetscViewerBinaryOpen(PETSC_COMM_WORLD,file2,
>     &     FILE_MODE_READ,fd,ierr)
>      call DAGetMatrix(da,MATMPIAIJ,A,ierr)
>      call MatLoad(A,fd,ierr)
which supposedly will load a matrix A which is stored by the following commands:
>     &     FILE_MODE_WRITE,fd,ierr)
>      call MatView(A,fd,ierr)
by another program (on a single core). The MatLoad() does work perfectly on a single core, however two or more cores make the program crash with the following error (see below)
> The programcall is
 mpirun -n 2 ./main
Is something broken with Petsc or do I need to set some extra parameters?
> Thanks in advance,
Leo van Kampenhout
PS. I'm using a build from last friday, since when I updated petsc-dev today using Mercurial I couldnt get it to configure or compile :S (which is another subject)
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: MatLoad is not supported for type: mpiaij!
> [0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Development HG revision: 84fec3ca75412473b06251029b58f2a68f1334f3  HG Date: Fri Aug 27 07:06:08 2010 +0200
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./main on a arch-linu named wingtip72 by csg4035 Wed Sep  1 15:52:11 2010
[0]PETSC ERROR: Libraries linked from /net/users/csg/csg4035/install/petsc-dev/arch-linux-gnu-c-debug/lib
[0]PETSC ERROR: Configure run at Fri Aug 27 08:37:32 2010
> [0]PETSC ERROR: Configure options
[0]PETSC ERROR: MatLoad() line 843 in src/mat/interface/matrix.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100902/6a6fbdcc/attachment.html>
