[petsc-dev] [Fortran] MatLoad() error: MatLoad is not supported for type: mpiaij!
    Shri
    abhyshr at mcs.anl.gov
    Thu Sep  2 09:30:16 CDT 2010
Pushed. Please let me know if you get any errors.
Shri
----- Barry Smith  wrote:
>  if (size > 1) {     /* change viewer to display matrix in natural ordering */    ierr = MatShellSetOperation(A, MATOP_VIEW, (void (*)(void)) MatView_MPI_DA);CHKERRQ(ierr);    /* turn off loading of matrix because loading would require proper permutation I don't feel like writing now */    ierr = MatShellSetOperation(A, MATOP_LOAD, (void (*)(void)) 0);CHKERRQ(ierr);  }
  Shri,
    Could you please add the support for this? And push to petsc-dev
    Thanks
     Barry
On Sep 1, 2010, at 10:23 AM, Leo van Kampenhout wrote:
Using a DA, of equal size and type as the other one. The curious thing is that there are no problems on a single core run. (but that is not what I want ;)
2010/9/1 Barry Smith <bsmith at mcs.anl.gov>
   Did you get the matrix in the writer code using a DA or some other code that puts the vector from the 2d or 3d problem in the natural ordering on the binary file.
   Barry
On Sep 1, 2010, at 9:55 AM, Leo van Kampenhout wrote:
Hi all,
I'm having trouble with MatLoad on Petsc-Dev. Not sure if this problem also exists in the main PETSc 3.1 since my code won't compile on that.
> The problematic calls are as follows:
      call PetscViewerBinaryOpen(PETSC_COMM_WORLD,file2,
>     &     FILE_MODE_READ,fd,ierr)
      call DAGetMatrix(da,MATMPIAIJ,A,ierr)
>      call MatLoad(A,fd,ierr)
which supposedly will load a matrix A which is stored by the following commands:
     &     FILE_MODE_WRITE,fd,ierr)
>      call MatView(A,fd,ierr)
by another program (on a single core). The MatLoad() does work perfectly on a single core, however two or more cores make the program crash with the following error (see below)
> The programcall is
 mpirun -n 2 ./main
Is something broken with Petsc or do I need to set some extra parameters?
> Thanks in advance,
Leo van Kampenhout
PS. I'm using a build from last friday, since when I updated petsc-dev today using Mercurial I couldnt get it to configure or compile :S (which is another subject)
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: MatLoad is not supported for type: mpiaij!
> [0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Development HG revision: 84fec3ca75412473b06251029b58f2a68f1334f3  HG Date: Fri Aug 27 07:06:08 2010 +0200
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./main on a arch-linu named wingtip72 by csg4035 Wed Sep  1 15:52:11 2010
[0]PETSC ERROR: Libraries linked from /net/users/csg/csg4035/install/petsc-dev/arch-linux-gnu-c-debug/lib
[0]PETSC ERROR: Configure run at Fri Aug 27 08:37:32 2010
> [0]PETSC ERROR: Configure options
[0]PETSC ERROR: MatLoad() line 843 in src/mat/interface/matrix.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100902/2cb38ecf/attachment.html>
