[petsc-dev] configure usability
Jed Brown
jed at 59A2.org
Wed Sep 1 06:07:50 CDT 2010
On Wed, 1 Sep 2010 12:56:30 +0200, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Sep 1, 2010 at 12:55 PM, Jed Brown <jed at 59a2.org> wrote:
> > Two thoughts:
> > 1. Systematic deprecation system:
> > --with-shared doesn't give any errors today, but the option goes
> > unused (because it's now spelled --with-shared-libraries). I'd like
> > to see either (a) recognize the old spelling but warn of deprecation,
> > or (b) error giving the new spelling. This seems easy to do by
> > updating help.addArgument.
> Good idea. Will do it.
Thanks.
> > 2. It's common to misspell options, difflib is part of the standard library
> > (from 2.3)
> > http://docs.python.org/library/difflib.html#difflib.get_close_matches
> > and would enable a warning like
> > The option "--with-shard-libaries" was not used, maybe you meant
> > "--with-shared-libraries".
> > Configure is imperative (as opposed to declarative, or with all
> > options identified and available very early) so I don't think it's
> > feasible to provide comprehensive misspelled options help immediately,
> > but at least the unused options could be listed at the end. This
> > ought to just be a matter of having argDB log accesses, then at the
> > end, take all entries that were never accessed and compute Levenshtein
> > distance to the options that were accessed used to give suggestions.
> The first part, putting in access logging, has been on the list for a long
> time.
> We need to do it, but its a bit of programming.
Once you have access logging, the fuzzy matching is very easy, so more
incentive perhaps.
> > I'm not sure what to do if configure errors out early, it might be
> > hitting an error _because_ of an unused option, but there may be lots
> > of unused options at this stage (that are valid and really will be
> > used later).
> This is not really soluble now I think.
Yup.
Jed
