[petsc-dev] CUDA 3.2
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 19 11:22:50 CDT 2010
On Oct 19, 2010, at 10:12 AM, Jose E. Roman wrote:
> Probably you already tried, but I successfully built petsc-dev with CUDA 3.2 and the latest versions of thrust and cusp. See below the required patch for BuildSystem.
> Do you plan to support the latest versions only?
We plan to support only one version of thrust and cusp at a time. (It seems the cusp and thrust lag the CUDA x.x releases slightly and we track the cusp and thrust). Victor is updating now.
Barry
> Jose
> diff -r 7fcb25f97314 config/packages/cusp.py
> --- a/config/packages/cusp.py Fri Oct 15 23:22:39 2010 -0500
> +++ b/config/packages/cusp.py Tue Oct 19 17:10:15 2010 +0200
> @@ -4,7 +4,7 @@
> class Configure(config.package.Package):
> def __init__(self, framework):
> config.package.Package.__init__(self, framework)
> - self.version = '101' #Version 0.1.1
> + self.version = '102' #Version 0.1.2
> self.versionStr = str(int(self.version)/100000) + '.' + str(int(self.version)/100%1000) + '.' + str(int(self.version)%100)
> self.download = ['http://cusp-library.googlecode.com/files/cusp-v'+self.versionStr+'.zip']
> self.includes = ['cusp/version.h']
> diff -r 7fcb25f97314 config/packages/thrust.py
> --- a/config/packages/thrust.py Fri Oct 15 23:22:39 2010 -0500
> +++ b/config/packages/thrust.py Tue Oct 19 17:10:15 2010 +0200
> @@ -4,7 +4,7 @@
> - self.version = '100201' #Version 1.2.1
> + self.version = '100300' #Version 1.3.0
> self.download = ['http://thrust.googlecode.com/files/thrust-v'+self.versionStr+'.zip']
> self.includes = ['thrust/version.h']
> diff -r 7fcb25f97314 config/setCompilers.py
> --- a/config/setCompilers.py Fri Oct 15 23:22:39 2010 -0500
> +++ b/config/setCompilers.py Tue Oct 19 17:10:15 2010 +0200
> @@ -513,7 +513,7 @@
> def checkCUDACompiler(self):
> '''Locate a functional CUDA compiler'''
> - requiredVersion = '3.1'
> + requiredVersion = '3.2'
> if 'with-cudac' in self.framework.argDB and self.framework.argDB['with-cudac'] == '0':
> if 'CUDAC' in self.framework.argDB:
> del self.framework.argDB['CUDAC']
