[petsc-dev] downloadname usage inconsistency in	config.package.Package?
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Oct 18 20:26:11 CDT 2010
On Oct 18, 2010, at 7:46 PM, Dmitry Karpeev wrote:
> In config/BuildSystem/config/package.py we have this:
> class Package:
>  <snip>
> def setupHelp(self,help):
>    '''Prints help messages for the package'''
>    <snip>
>    if self.download and not self.download[0] == 'redefine':
>      help.addArgument(self.PACKAGE,
> '-download-'+self.package+'=<no,yes,filename>',
> nargs.ArgDownload(None, 0, 'Download and install '+self.name))
>    return
> Then:
>  def checkDownload(self, requireDownload = 1):
>    '''Check if we should download the package, returning the install
> directory or the empty string indicating installation'''
>    if not self.download:
>      return ''
>    downloadPackage = 0
>    downloadPackageVal =
> self.framework.argDB['download-'+self.downloadname.lower()]
>    <snip>
> An apparent inconsistency if not self.downloadname.tolower() == self.package.
> Is this a bug?
   I think it just means the help message would be wrong if downloadname was not package.
    The problem I think is that downloadname might not be defined at the time of setupHelp() so cannot be used in printing the help message.
> Also, why ".tolower()" all over the place?
   So that you only need to type smalls in your -download-xxxx
> Dmitry.
