[petsc-dev] wrong makefile variables?
Sat Oct 16 15:02:30 CDT 2010
   Ok, config/PETSc/Configure.py will automatically put PETSC_LIB_BASIC = -lpetsc into $PETC_ARCH/conf/petscvariables when run with single library.
    Barry
   BTW: PETSC_LIB_VARIABLE was just an internal variable in the makefile system for making other variables, since I didn't know you used it I didn't try to preserve it. I didn't mess it up just to bug you.
On Oct 16, 2010, at 2:32 PM, Lisandro Dalcin wrote:
> On 16 October 2010 22:21, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  So all you need is a single variable
>> or
>> PETSC_LIB_BASIC = -lpetscts .... -lpetscsys
>> I'll put that in today if that is what you need.
> Yes, that's what I need, and that was available a week ago. So yes,
> please restore it.
>>   Barry
>> On Oct 16, 2010, at 1:34 PM, Lisandro Dalcin wrote:
>>> On 16 October 2010 19:17, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>  Maybe if you told/showed me exactly how you use it we can come up with the optimal set of variables you want?
>>> Take a look here to what I'm currently using:
>>> http://code.google.com/p/petsc4py/source/browse/conf/core/confcore.py#144
>>> I'm not saying that this is optimal, I've always used what PETSc provides.
>>>>   Do you want a flag that says single library or multiple libraries?
>>> Perhaps that could work, but...
>>>>   Do you want a variable with the list of the PETSc libraries?
>>> That's what I was used to get with PETSC_LIB_BASIC. That variable
>>> expanded to "-lpetsc" for single-lib builds, and "-lpetscts
>>> -lpetscsnes ..." for the multi-lib case.
>>>>   Something else?
>>> If you could provide the correct list of PETSc libs in
>>> PETSC_LIB_BASIC, that would be nice, because my code would continue
>>> working with previous 3.0.0 and 3.1 releases.
>>>>   Barry
>>>> On Oct 16, 2010, at 9:44 AM, Lisandro Dalcin wrote:
>>>>> On 16 October 2010 16:23, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>> On Oct 16, 2010, at 3:43 AM, Lisandro Dalcin wrote:
>>>>>>> It seems that after changes to BuildSystem, the makefile variables
>>>>>>> PETSC_LIB_BASIC and PETSC_EXTERNAL_LIB_BASIC are not properly set for
>>>>>>> single-library builds.
>>>>>>   This is a change.  ./configure now generates PETSC_EXTERNAL_LIB_BASIC  and PETSC_LIB_BASIC is never used
>>>>>>  Barry
>>>>> How should I figure if PETSc is using single vs. multiple library
>>>>> builds (remember petsc4py inspect makefile variables to get PETSc
>>>>> stuff)?
>>>>> Any chance you could still generate the correct PETSC_LIB_BASIC, even
>>>>> if core PETSc does not use it?
>>>>>>> A few days ago we had:
>>>>>>> $ grep _BASIC $PETSC_ARCH/conf/petscvariables
>>>>>>> PETSC_CONTRIB_BASIC = -lpetsc
>>>>>>> PETSC_SNES_LIB_BASIC = -lpetsc
>>>>>>> PETSC_KSP_LIB_BASIC = -lpetsc
>>>>>>> PETSC_MAT_LIB_BASIC = -lpetsc
>>>>>>> PETSC_VEC_LIB_BASIC = -lpetsc
>>>>>>> PETSC_DM_LIB_BASIC = -lpetsc
>>>>>>> PETSC_TS_LIB_BASIC = -lpetsc
>>>>>>> PETSC_SYS_LIB_BASIC = -lpetsc
>>>>>>> but now:
>>>>>>> SL_LINKER_LIBS = ${PETSC_EXTERNAL_LIB_BASIC}
>>>>>>> PETSC_EXTERNAL_LIB_BASIC = -lX11 -llapack -lblas -lm
>>>>>>> -Wl,-rpath,/usr/lib64/mpich2 -L/usr/lib64/mpich2
>>>>>>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.1
>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.4.1 -ldl -lmpich -lopa -lpthread
>>>>>>> -lrt -lgcc_s -lmpichf90 -lgfortran -lm -lm -ldl -lmpich -lopa
>>>>>>> -lpthread -lrt -lgcc_s -ldl
>>>>>>> Could any of you check and fix this?
>>>>>>> Lisandro Dalcin
>>>>>>> CIMEC (INTEC/CONICET-UNL)
>>>>>>> Predio CONICET-Santa Fe
>>>>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>>>>> Tel: +54-342-4511594 (ext 1011)
>>>>>>> Tel/Fax: +54-342-4511169
>>>>> Lisandro Dalcin
>>> Lisandro Dalcin
> Lisandro Dalcin
