[petsc-dev] Fwd: [petsc-maint #54348] New Example for High-Order Finite Elements for Ksp Test Suite
Barry Smith
bsmith at mcs.anl.gov
Mon Oct 11 12:17:49 CDT 2010
Begin forwarded message:
> From: Travis Austin <austin at txcorp.com>
> Date: October 11, 2010 12:04:10 PM CDT
> To: petsc-maint Maintenance <petsc-maint at mcs.anl.gov>
> Subject: [petsc-maint #54348] New Example for High-Order Finite Elements for Ksp Test Suite
> Reply-To: petsc-maint at mcs.anl.gov, Travis Austin <austin at txcorp.com>
> Hi,
> Last week I posted on petsc-dev that I had a high-order finite element example that could be added to the ksp test suite. Jed
> said it would be welcomed. It is based on the existing ex3 parallel example. It consists of one file but needs a few additional
> subroutines included at the end of main.
> Travis Austin
> Travis Austin, Ph.D.
> Tech-X Corporation
> 5621 Arapahoe Ave, Suite A
> Boulder, CO 80303
> Hi,
> Travis Austin
> Tech-X Corporation
> Boulder, CO 80303
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101011/54d2b23c/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101011/54d2b23c/attachment.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101011/54d2b23c/attachment-0001.html>
