[petsc-dev] additional changes to IS interface
Barry Smith
bsmith at mcs.anl.gov
Thu Oct 7 15:07:36 CDT 2010
I have pushed what I hope are my last changes to IS for awhile.
1) ISCreateBlock() now takes the PetscCopyMode argument (like ISCreateGeneral()) allowing reuse of the index data without a copy
2) ISCreateBlock()), ISBlockSetIndices() and ISBlockGetIndices() now work with indices relative to the block rather than the individual entries, for example If you wish to index the values {0,1,4,5}, then use
a block size of 2 and idx of {0,2}. (It previously was idx of {0,4}. So make sure you update any of your code that uses the Blocked indices. This was to make consistent with usage in Vec/MatSetValuesBlocked() etc and is (argued by some and I agreed) a more reasonable paradigm.
3) There now exists ISToGeneral() instead of only ISStrideToGeneral().
Happy computing,
Barry
