[petsc-dev] configure checking for FC but PETSc not using them
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 5 13:42:56 CDT 2010
OK, I can't figure out where HAVE_FORTRAN and HAVE_F90 are defined in BuildSystem or PETSc. I think basically you need to find out where they are defined and provide the option to not have them defined.
Note: I did find where you define them for cmake :-)
Barry
On Oct 5, 2010, at 1:02 PM, Jed Brown wrote:
> On Tue, Oct 5, 2010 at 19:59, Barry Smith <bsmith at mcs.anl.gov> wrote:
> How about a --with-fortran-interface which is true by default unless --with-fc is set to zero, but you can turn it off and the FC tests are still done?
> Perfect.
> Jed
