[petsc-dev] changed ISCreateGeneral/NC/WithArray()
Jed Brown
jed at 59A2.org
Sun Oct 3 17:58:29 CDT 2010
Can anyone think of a better mnemonic, I find PETSC_OWN_VALUES to be
ambiguous without reading the man page?
Jed
On Oct 3, 2010 7:57 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
I find the three routines ISCreateGeneral(), ISCreateGeneralNC() and
ISCreateGeneralWithArray() to be confusing and code redundant.
Therefore in PETSc-dev I have introduced
/*E
PetscCopyMode - Determines how an array passed to certain functions is
copied or retained
Level: beginner
$ PETSC_COPY_VALUES - the array values are copied into new space, the user
is free to reuse or delete the passed in array
$ PETSC_OWN_POINTER - the array values are NOT copied, the object takes
ownership of the array and will free it later, the user cannot change or
$ delete the array. The array MUST have been obtained
with PetscMalloc(). Hence this mode cannot be used in Fortran.
$ PETSC_USE_POINTER - the array values are NOT copied, the object uses the
array but does NOT take ownership of the array. The user cannot use
the array but the user must delete the array after
the object is destroyed.
E*/
typedef enum { PETSC_COPY_VALUES, PETSC_OWN_POINTER, PETSC_USE_POINTER}
PetscCopyMode;
extern const char *PetscCopyModes[];
and merged ISCreateGeneral/NC/WithArray() into a single routine with an
additional PetscCopyMode argument.
I have also merged ISLocalToGlobalMappingCreate() and
ISLocalToGlobalMappingCreateNC() into a single routine.
There may be other places we can use this paradigm in the future, keep your
eyes open,
Happy computing,
Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101004/4fb80515/attachment.html>
