[petsc-dev] changed ISCreateGeneral/NC/WithArray()
Barry Smith
bsmith at mcs.anl.gov
Sun Oct 3 17:51:18 CDT 2010
Well it is always "with array" since you always need to provide an array of indices, so why both with the redundant "withArray" (With VecCreateSeqWithArray() there is also a VecCreateSeq() that does not take an array, hence WithArray in that case is not redundant)?
Regarding having two routines: I found having three almost identical routines unneededly complicated. You still want to have two routines, one is just a subset of the functionality of the second. That is redundant and hence unneeded.
I do appreciate your suggestions, please keep on having them even if they don't always convince me.
Barry
On Oct 3, 2010, at 5:45 PM, Lisandro Dalcin wrote:
> On 3 October 2010 14:57, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> I find the three routines ISCreateGeneral(), ISCreateGeneralNC() and ISCreateGeneralWithArray() to be confusing and code redundant.
>> Therefore in PETSc-dev I have introduced
>> /*E
>> PetscCopyMode - Determines how an array passed to certain functions is copied or retained
>> Level: beginner
>> $ PETSC_COPY_VALUES - the array values are copied into new space, the user is free to reuse or delete the passed in array
>> $ PETSC_OWN_POINTER - the array values are NOT copied, the object takes ownership of the array and will free it later, the user cannot change or
>> $ delete the array. The array MUST have been obtained with PetscMalloc(). Hence this mode cannot be used in Fortran.
>> $ PETSC_USE_POINTER - the array values are NOT copied, the object uses the array but does NOT take ownership of the array. The user cannot use
>> the array but the user must delete the array after the object is destroyed.
>> E*/
>> typedef enum { PETSC_COPY_VALUES, PETSC_OWN_POINTER, PETSC_USE_POINTER} PetscCopyMode;
>> extern const char *PetscCopyModes[];
>> and merged ISCreateGeneral/NC/WithArray() into a single routine with an additional PetscCopyMode argument.
>> I have also merged ISLocalToGlobalMappingCreate() and ISLocalToGlobalMappingCreateNC() into a single routine.
>> There may be other places we can use this paradigm in the future, keep your eyes open,
>> Happy computing,
>> Barry
> I would prefer to have:
> ISCreateGeneralWithArray(comm,n,ptr,copy_mode,&is);
> and then implement
> ISCreateGeneral(comm,n,ptr,&is) {
> return ISCreateGeneralWithArray(comm,n,ptr,PETSC_COPY_VALUES,&is);
> What do you think?
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
