[petsc-dev] CMake proof of concept
    Jed Brown
    jed at 59A2.org
    Mon May 31 10:23:02 CDT 2010
In this latest buzz about build systems and IDE integration, I added a
CMake build to PETSc.  It is entirely contained in bin/maint/cmakegen.py
and bin/maint/cmakeboot.py and supports multiple PETSC_ARCH, Fortran,
C++ (currently only with-c-support), complex/precision/etc, with and
without single-library, static or shared, and coexists with the existing
build system.  The primary motivation for this was (a) dependency
analysis, (b) parallel builds, (c) IDE integration, (d) more
sophisticated test summaries (later, maybe,
cf. http://public.kitware.com/dashboard.php).
Usage:
After generating ftn-auto if necessary, run
which creates a PETSC_ARCH-agnostic $PETSC_DIR/CMakeLists.txt which
describes the build in terms of the variables that might be set by each
PETSC_ARCH (I put it all in one file so as to be as unintrusive as
possible).  This might need to be rerun after pulling new sources, but
it is fast (<1 second).
Then, after running configure for your given PETSC_ARCH, run
which initializes CMake's build in that directory.  This normally only
needs to be run once, CMake's cache and dependencies will be updated as
necessary (e.g. a source file includes different headers or
CMakeLists.txt changes after rerunning cmakegen.py).  This script
accepts arguments to be passed on to CMake, such as
  -G'Eclipse CDT4 - Unix Makefiles'
which creates an Eclipse project file with an accompanying
Makefile-based build.  I've tested import with Eclipse, KDevelop, and Qt
Creator; a variety of other IDEs are supported (including XCode and
Visual Studio) but I don't use those platforms so can't test them).
Note that most IDEs have a way to manage multiple "build
configurations", which correspond to multiple values of PETSC_ARCH.
Usually you point them to $PETSC_DIR/CMakeLists.txt and then specify a
build directory which would be $PETSC_DIR/$PETSC_ARCH for whichever
configurations you want.
Both of these steps should be very fast and idempotent.  At this point,
the values of PETSC_DIR and PETSC_ARCH (in your environment) are no
longer of any consequence, everything is determined by the location of
the build directory.  Managing multiple builds is easy, for example,
just run (assuming a Makefile based build)
  $ make -C arch1 -j3 &  make -C arch2 -j5 &
to update the libraries for multiple configurations at once with several
processes each.  The object files reside in $PETSC_ARCH/CMakeFiles so
their presence doesn't interfere with other builds and refreshing is
fast (only rebuild when necessary, do-nothing rebuild takes less than 1
second without single-library, a slightly more with single-library).
I currently don't do anything with examples, I suggest building them as
usual with PETSc's current system until/unless they are added to this.
I haven't provided a public PETScConfig.cmake and haven't addressed
installation.
I declared a CMake compatibility version of 2.6 because that's the
oldest I've tested.  The scripts cmakegen.py and cmakeboot.py require
Python 2.5 because I wanted newer language features.  It could easily be
ported to older pythons if that became important, but the whole thing is
just a proof of concept at this stage.  These versions are not hard to
come by and I would imagine that everyone's development machine is
relatively current.
Let me know about any issues.
Jed
