[petsc-dev] Win32 and MPIAPI calling convention
Satish Balay
balay at mcs.anl.gov
Fri May 21 11:23:49 CDT 2010
On Fri, 21 May 2010, Lisandro Dalcin wrote:
> I noticed that MPIAPI is being using for MPI callbacks, likely in
> order to suport Microsoft HPC Cluster Pack, right?
yes.
> Well, if you want to support DeinoMPI (yet another child of MPICH2),
> you have to use MPI_CALL.
> Perhaps just:
> #if defined(DEINO_MPI)
> #define MPIAPI MPI_CALL
> #endif
> would do the trick.
If this indeed works - you can push it to petsc-31 repo..
> PS: Just FYI, MS MPI has a bug in its headers, if you ever need to
> call MPI_File_{c2f|f2c}, you can hostfix like this:
> #undef MPI_File_c2f
> #define MPI_File_c2f PMPI_File_c2f
> #undef MPI_File_f2c
> #define MPI_File_f2c PMPI_File_f2c
Currently they are not used in petsc - so I guess we don't need them yet.
> However, I do not know if MS MPI do actually have any support for any Fortran.
I does work with intel fortran compiler [with MS C]
Satish
