[petsc-dev] MatDestroy_MUMPS
Jed Brown
jed at 59A2.org
Thu May 20 17:23:18 CDT 2010
I'm not a fan of invalid frees so I pushed this thing which seems to
Work for Me. Could one of you involved in this check if it's correct?
changeset: 15992:979f106f87fc
tag: tip
user: Jed Brown <jed at 59A2.org>
date: Fri May 21 00:14:23 2010 +0200
files: src/mat/impls/aij/mpi/mumps/mumps.c
description:
MUMPS: Must use Free2 and Free3 with Malloc2 and Malloc3
Instead of this super fragile code (which duplicates both creation logic
and knowledge of internals of ConvertToTriples_*_*), how about adding a
member describing how the memory was allocated, or allocate zero space
for the val member (into a val_allocated member if you need (lu->val) to
be false).
Jed
