[petsc-dev] needing a clone of petsc-dev
    Jed Brown
    jed at 59A2.org
    Thu May 20 14:29:11 CDT 2010
On Thu, 20 May 2010 16:19:48 -0300, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Could any of you with admin access clone petsc-dev to petsc-dev-ts ?
Lisandro, you can make a new clone with
  hg clone . ssh://petsc//hg/petsc/temp/petsc-dev-ts
or, if your .ssh/config isn't set up, the more verbose
  hg clone . ssh://petsc@petsc.cs.iit.edu//hg/petsc/temp/petsc-dev-ts
Jed
