[petsc-dev] changes to the TS structure
    Matthew Knepley
    knepley at gmail.com
    Wed May 19 17:15:17 CDT 2010
So the DM is a sort of Builder patter object. I like that.
   Matt
On Wed, May 19, 2010 at 3:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On May 19, 2010, at 3:19 PM, Lisandro Dalcin wrote:
> > On 19 May 2010 16:18, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> On May 19, 2010, at 2:07 PM, Jed Brown wrote:
> >>> On Wed, 19 May 2010 15:17:19 -0300, Lisandro Dalcin <dalcinl at gmail.com>
> wrote:
> >>>> If you do have the SNES availabe at the point you setIFunction(vec,
> >>>> func), then yes, there is no much to gain from having TS hold a ref to
> > Barry/Jed, many thanks for your comments. Now things are far more
> > clear. So we should make KSPGetSolution(), KSPGetRHS(), etc. create
> > the inner vecs, and similarly for SNES and TS.
>    We could. I don't know all the ramifications of doing this and if it
> could break things.
>   Also, with my plan to "merge" the "style" of DMMG into the TS, SNES, and
> KSP object would have the DM object be responsible for setting some of the
> correct values into those inner objects. So, for example, with
> KSPGetSolution() the KSP would do a VecCreate() with the appropriate
> MPI_Comm but the DM would then set the appropriate layout/sizes to that Vec.
>  A crude form of this would be
> KSPGetSolution(KSP ksp,Vec *v)
>   if (!ksp->vec_sol) {
>      VecCreate(ksp->comm,v);
>      if (ksp->dm) {
>         DMSetUpGlobalVector(ksp->dm,v);
> Note that this requires pulling the VecCreate() part out of
> DMCreateGlobalVector();  so that it just "finishes" the job of creating the
> vector. Similar for PCGetOperators()
> PCGetOperators(PC pc,Mat *A) /* for the example pretend takes only one
> matrix */
>   if (!pc->mat) {
>      ierr = MatCreate(pc->comm,A);
>      if (pc->dm) {
>         DMSetUpMatrix(pc->dm,A);
>  where similarly DMSetUpMatrix() is like DMGetMatrix() with the the
> MatCreate() part.
> The details of all this are not yet clear in my mind.
>   Barry
> > Lisandro Dalcin
> > CIMEC (INTEC/CONICET-UNL)
> > Predio CONICET-Santa Fe
> > Colectora RN 168 Km 472, Paraje El Pozo
> > Tel: +54-342-4511594 (ext 1011)
> > Tel/Fax: +54-342-4511169
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100519/44e30b13/attachment.html>
