[petsc-dev] GCC warnings
    Jed Brown
    jed at 59A2.org
    Sat May 15 17:12:19 CDT 2010
On Sat, 15 May 2010 18:25:10 -0300, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> libfast in: /usr/local/petsc/dev/src/mat/impls/aij/seq
> aijfact.c: In function ‘MatCholeskyFactorNumeric_SeqAIJ’:
> aijfact.c:2084: warning: ‘newshift’ may be used uninitialized in this function
> aijfact.c: In function ‘MatLUFactorNumeric_SeqAIJ’:
> aijfact.c:474: warning: ‘newshift’ may be used uninitialized in this function
> inode.c: In function ‘MatLUFactorNumeric_SeqAIJ_Inode’:
> inode.c:1201: warning: ‘newshift’ may be used uninitialized in this function
You must have an older checkout, these line numbers don't agree with the
present tip and newshift is always initialized.
Jed
