[petsc-dev] field split/schur complement, incompressible flow
Lisandro Dalcin
dalcinl at gmail.com
Wed May 12 11:27:18 CDT 2010
On 12 May 2010 13:17, Jed Brown <jed at 59a2.org> wrote:
> On Wed, 12 May 2010 09:32:23 -0500, Chris Kees <christopher.e.kees at usace.army.mil> wrote:
>> Thanks a lot. Does PCFieldSplitSetFields() implicitly number the
>> fields it creates or am I missing something more fundamental e.g.
>> PCFieldSplitSetFields(pc,isPressure)// field 0 for pressure
>> PCFieldSplitSetIS(pc,isVelocity)//field 1 for the 3 velocity components
> You use *either* PCFieldSplitSetFields() or PCFieldSplitSetIS(). If
> your matrix has a "block size" (e.g. it's BAIJ or you called
> MatSetBlockSize) then you can define the split at runtime:
> -pc_fieldsplit_0_fields 0 # pressure is in the first split
> -pc_fieldsplit_1_fields 1,2,3 # velocity in the second split
> You can set this programmatically with, e.g.
> PCFieldSplitSetFields(pc,1,(PetscInt[]){0});
> PCFieldSplitSetFields(pc,3,(PetscInt[]){1,2,3});
> If your spatial discretization does not have a natural block size, you
> should call PCFieldSplitSetIS() for both fields.
Chris is going to use this from Python, and I have to add support in
petsc4py. I think I'll have to provide a better API, something like:
pc.fieldSplitSetFields(0,[1,2,3],4) # (rho,[Ux,Uy,Uz],p)
or
pc.fieldSplitSetIS(is_rho, is_U, is_p)
and implement then by calling PCFieldSplitSet{Fields|IS} multiple times.
Does this API make sense?
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
