[petsc-dev] adding comm argument to PetscError() and friends
Matthew Knepley
knepley at gmail.com
Fri May 7 14:02:10 CDT 2010
On Fri, May 7, 2010 at 2:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On May 7, 2010, at 1:04 PM, Matthew Knepley wrote:
> On Thu, May 6, 2010 at 10:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> I'd like to add a MPI_Comm as the first argument to PetscError() and
>> friends.
>> In this way, if the same error is known over all the communicator ranks
>> it can print just one nice error message and stack instead of spewing out
>> many of the same messages all over the place.
>> Does anyone object to this?
> I am just worried that it will introduce deadlocks. If an error occurs on
> only one process
> and not another (like a NaN), but we use the entire communicator, we can
> get deadlock
> on the error message which will be very confusing.
> The idea is that by default we would pass in PETSC_COMM_SELF. Only when
> we KNOW 100% that ALL ranks in a process WILL FOR ABSOLUTE sure generate the
> same error would be pass the entire comm to SETERRQ() For example, if the
> user has set an invalid PC type etc. So a process generating a NAN would use
> only a PETSC_COMM_SELF in the SETERRQ().
> You are right that there is a chance when totally bizarre shit happens
> that rank 1 of a comm calls SETERRQ() but rank 0 does not; then no
> appropriate error message will be printed. I don't see a way to totally
> avoid this chance. So we can
> 1) ignore this chance and make the change and see what happens
> 2) leave things the same as they are now.
> Even if it turns out we cannot have only rank 0 of the SETERRQ() print
> the message because bizarre shit happens too often, I think conceptually it
> is the right thing to do to pass in the MPI_Comm over which the error
> happens. So I'd like to make the chance and we can always take out the
> control over printing by rank 0 if it is a problem (i.e. the default error
> handles could ignore the comm).
> I'm going to try this and see if I can work out the kinks before
> pushing.
> Is there a nice MPI way of checking
> whether everyone is present, and if not then just use the current method?
> No, absolutely not since that would require communication with everyone
> who may not be there.
I was thinking of something like a barrier+probe+cancel (if necessary).
Matt
> Barry
> Matt
>> It does mean for each SETERRQXXX() we call we need to select the correct
>> comm that is passed in. I will do all that, worst case just use
>> MPI_COMM_SELF for some and get the same effect as today.
>> Barry
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100507/3b41aba7/attachment.html>
