[petsc-dev] reminder never use #include "mylocalinclude.h" in PETSc source
Tue May 4 12:51:58 CDT 2010
On May 4, 2010, at 9:51 AM, Jed Brown wrote:
> On Tue, 4 May 2010 11:37:14 -0500, Matthew Knepley
> <knepley at gmail.com> wrote:
>> I see. Yes, it currently uses the makefile organization. This is the
>> kind of metadata that Barry would like in a DB rather than in
>> makefiles.
> It would be easy to convert between being spread out in the makefiles
> and being held in some central location.  For instance, something like
> builder.py, run at the end of configuration time, could instead of
> building the project, write a single tupfile [1] for all of PETSc, and
> then we could rejoice with fast correct builds, even after
> reconfiguring.
> I think the metadata itself belongs with the implementations (more or
> less where it is currently)
    Absolutely. It does not belong in some centralized place; it
belongs with each chunk of code.
    In fact, could/should we move it into the source files directly
and thus not need a file with this meta-data at all. The python tool
can just as easily get it out of the source files then the makefile.
(Currently there is one copy of this data per directory, it is not per
file; should we change it to per file, I'm not sure.)
    Barry
> unless we are actually working with an
> image-based system (which does not look likely in the near future).
> Jed
> [1] For those who not in the know: http://gittup.org/tup/make_vs_tup.html
