[petsc-dev] Fwd: [ANN] MacHg 0.9.0 : OSX gui client for Mercurial
    Barry Smith
    bsmith at mcs.anl.gov
    Mon May  3 09:59:14 CDT 2010
Begin forwarded message:
> From: "Lichtner, Peter C" <lichtner at lanl.gov>
> Date: May 3, 2010 6:56:32 AM PDT
> To: "ascem-hpc-dev at lanl.gov" <ascem-hpc-dev at lanl.gov>
> Subject: FW: [ANN] MacHg 0.9.0 : OSX gui client for Mercurial
> For those Mac users!
> ...Peter
> ------ Forwarded Message
> From: Jason Harris <jason at jasonfharris.com>
> Date: Sun, 2 May 2010 17:20:45 -0600
> To: mercurial <mercurial at selenic.com>
> Subject: [ANN] MacHg 0.9.0 : OSX gui client for Mercurial
> Hi All,
> I am pleased to announce the initial public release of MacHg.
> MacHg is a gui client for Mercurial. It runs under OSX 10.6 (Snow
> leopard). It is free to use and donation ware.
> Links
> You can get an executable application here:
> http://jasonfharris.com/machg/downloads/downloads.html
> You can view (and clone) the MacHg sources at:
> http://bitbucket.org/jfh/machg
> You can view a screen cast  'MacHg Introduction' at:
> http://jasonfharris.com/machg/screencasts/introduction/screencast_introduction.html
> Discussion group about MacHg at:
> http://groups.google.com/group/machg_mercurial <http://groups.google.com/group/machg_mercurial?lnk=gcimh
> MacHg Features
> - Document based structure with multiple repositories per document
> - View incoming and outgoing at a glance between compatible
> repositories
> - Auto refreshes the status of tracked files when they change
> - Incremental loading of history (for efficiency)
> - Works with large repositories (ie for example can load and work
> with the Mozilla repository which is 3.35Gb)
> - Fully compatible with command line Mercurial (You can make changes
> on the command line and they are reflected in MacHg.)
> - Fully multi-threaded using Grand Central Dispatch and threading
> goodness
> - File browser view to work with files
> - History view to explore the changeset history
> - Differences view to explore the historical changes between
> different revisions
> - Interacting with other repositories: pull, push, incoming,
> outgoing, clone, etc
> - Contextual menus and shortcuts in many places
> - Diff multiple files at once
> - Renaming, merging, updating, reverting, adding files, removing
> files, etc
> - Add and remove local tags, global tags, bookmarks, and branches
> - Interface to history editing: collapse, histedit, rebase, strip
> - Importing and exporting of patches
> - Uses the Sparkle framework for "in application" updates
> Contributing
> If you would like to contribute I would be happy to receive and
> acknowledge help in a large number of areas, including:
> - Testing
> - Documentation (MacHg has some documentation but it would be nice
> to have a much more complete set of documentation.)
> - Cocoa coding (Lots of potential enhancements here)
> - Mercurial extension writing (There are a few extensions I could
> use help with: for example, around permissibility of dragging and
> dropping in history rewriting, etc.)
> - Translating (Especially those who have experience using Apple's
> polyglot tool, etc.)
> - Web designers (There are a number of enhancements to be made to
> web pages, wikis, etc.)
> - Graphic design (Icon design, etc.)
> Thanks,
>  Jason
> ------ End of Forwarded Message
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100503/f25b5cde/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100503/f25b5cde/attachment.txt>
