[petsc-dev] DD FAQ
    Barry Smith
    bsmith at mcs.anl.gov
    Sun May  2 17:46:16 CDT 2010
On Apr 26, 2010, at 9:03 AM, Jed Brown wrote:
> The FAQ mentions PCNN, but the advice "-pc_type nn" is completely
> inadequate to actually use this method, and the referenced example
> does
> not exist.  I have removed it's mention from the "Domain
> Decomposition"
> answer, I think it needs a working example in order to be mentioned
> there.  Also, ex2 -pc_type nn -mat_type fails with a seg-fault, I
> haven't investigated why.
> Barry, PCEXOTIC does have a working example, should it be mentioned
> here, or do you consider it to be a toy that users needn't bother
> trying
> to use.
    Done
> As for future DD directions, have you thought about what is
> necessary to
> provide quasi-generic support for optimized Schwarz.  I was only
> vaguely
> aware of this method until recently, but this approach seems to offer
> significant potential, especially for some indefinite problems.
    I assume you mean where you use "optimized" linear combinations of
solutions in overlapped regions? I am only vaguely aware as well. I've
attempted to ignore them all these years. I don't know how to tune
them. We currently use VecScatter to put in the overlapped values; now
we'd need to multiple each value by some scale factor before putting
in. I hate to increase the complexity of VecScatter even more by
adding this support but we could.
    Barry
> Jed
