[petsc-dev] Apple sadness
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Mar 31 16:48:44 CDT 2010
On Mar 31, 2010, at 2:19 PM, Sean Farley wrote:
> I have finally figured out that gdb will not read any symbols for
> source
> that does not have the object file with it. So when PETSc deletes the
> .o's after achiving, all I get is a stack. When I save the
> application .o
> that I am running, at least I can see those symbols. Is this universal
> on Mac. Can I fix it?
> This has happened to me since Leopard. In fact, it was the first
> time I ever emailed the petsc list :-) The fix came from Barry and
> comment out the line in the makefile that deletes the temporary .o's
> I believe the error was that there was no flag to stuff the debug
> objects in the dynamic library. Was that right, Barry?
> Sean
   Matt,
    Sean's understanding is my understanding. Here is my understanding
1)  This is only a problem with shared libraries (with static
libraries it finds the debug symbols).
2) If you don't delete the .o after making the shared library then it
finds the symbols
3) my reading of the ld manual page is that the symbols SHOULD be put
into the dylib; I do not understand why they are not, google searches
never helped me resolve this issue
4) When I want to debug an application I use something like make ex1
RM=/usr/bin/true and ex1.o is kept around so it can find the symbols
for ex1
    So, try removing the line               ${RM} -rf $
{INSTALL_LIB_DIR}/$$LIBNAME.tmp-petsc-shlib; \  from conf/rules and
then make the shared library. Can you now find the symbols in the
debugger? Is there a good permanent fix for this?
    Barry
