[petsc-dev] doc errors
Wed Mar 24 18:20:56 CDT 2010
I usually \mathrm for stuff like this.
   Matt
On Wed, Mar 24, 2010 at 6:13 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Jed,
> I get doc errors due to
> http://petsc.cs.iit.edu/petsc/petsc-release-3.1/rev/34db3f4fbf0b
> 106] [107]
> ! Undefined control sequence.
> l.4336    dt^{n} = dt_{\text
>                            {increment}}*dt^{n-1}*\frac{|| F(u^{n-1})
> Reverting the above changest fixes the problem. Can you check on this?
> Note there is also a spurious '40%' in the change.
> satish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100324/52c13b9e/attachment.html>
