[petsc-dev] -dmmg_form_function_ghost
Barry Smith
bsmith at mcs.anl.gov
Wed Mar 24 17:04:35 CDT 2010
Sorry, I was so stunned when I saw that option I just automatically
nuked it.
I have pushed 3.1 and dev with the option again.
Does your code support ghosted finite differences? With this option?
Barry
On Mar 24, 2010, at 4:56 PM, Jed Brown wrote:
> I know this was an absolutely horrendous API, but this patch
> completely
> removed the option which makes ex48 fail (and certainly some user
> code).
> Releaes-3.1 either needs to get a proper API for this, or the option
> needs to remain available. DMMGFormFunctionGhost is currently
> unreachable.
> (I'll add some ex48 tests to get them run in the nightlies, I should
> have done this long ago.)
> Jed
> changeset: 15513:e8e19296a5dc
> parent: 15511:2cefbdbb44a8
> user: Barry Smith bsmith at mcs.anl.gov
> date: Wed Mar 24 16:39:07 2010 -0500
> files: src/snes/utils/damg.c src/snes/utils/damgsnes.c
> description:
> fixed bug in DMMGCreate() that it ALWAYS used ghosted coloring even
> when it would not work.
> diff --git a/src/snes/utils/damg.c b/src/snes/utils/damg.c
> --- a/src/snes/utils/damg.c
> +++ b/src/snes/utils/damg.c
> @@ -65,7 +65,7 @@
> p[i]->user = user;
> p[i]->updatejacobianperiod = 1;
> p[i]->updatejacobian = PETSC_TRUE;
> - p[i]->isctype = IS_COLORING_GHOSTED; /* default to faster
> version, requires DMMGSetSNESLocal() */
> + p[i]->isctype = IS_COLORING_GLOBAL;
> ierr = PetscStrallocpy(MATAIJ,&p[i]-
> >mtype);CHKERRQ(ierr);
> *dmmg = p;
> diff --git a/src/snes/utils/damgsnes.c b/src/snes/utils/damgsnes.c
> --- a/src/snes/utils/damgsnes.c
> +++ b/src/snes/utils/damgsnes.c
> @@ -942,16 +942,9 @@
> CHKMEMQ;
> ierr = PetscObjectGetCookie((PetscObject) dmmg[0]-
> >dm,&cookie);CHKERRQ(ierr);
> if (cookie == DM_COOKIE) {
> - PetscTruth flag = PETSC_FALSE;
> - /* it makes no sense to use an option to decide on ghost, it
> depends on whether the
> - formfunctionlocal computes ghost values in F or not. */
> - ierr = PetscOptionsGetTruth(PETSC_NULL, "-
> dmmg_form_function_ghost", &flag,PETSC_NULL);CHKERRQ(ierr);
> - if (flag) {
> - ierr =
> DMMGSetSNES(dmmg,DMMGFormFunctionGhost,computejacobian);CHKERRQ(ierr);
> - } else {
> - ierr =
> DMMGSetSNES(dmmg,DMMGFormFunction,computejacobian);CHKERRQ(ierr);
> + ierr =
> for (i=0; i<nlevels; i++) {
> + dmmg[i]->isctype = IS_COLORING_GHOSTED; /* switch to
> faster version since have local function evaluation */
> ierr = DASetLocalFunction((DA)dmmg[i]-
> >dm,function);CHKERRQ(ierr);
> dmmg[i]->lfj = (PetscErrorCode (*)(void))function;
> ierr = DASetLocalJacobian((DA)dmmg[i]-
> >dm,jacobian);CHKERRQ(ierr);
