[petsc-dev] PETSC's compilation
David sheehan david.sheehanjr at gmail.com
Wed Mar 24 14:03:09 CDT 2010
How can I be added in the list of petsc-maint? thanks.
David
On Wed, Mar 24, 2010 at 12:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Mar 24, 2010 at 12:35 PM, David sheehan <david.sheehanjr at gmail.com
> > wrote:
>> Matt already moved it to petsc-maint before.
>> can you help me to fix the build-up of PETSC and HYPRE? thanks in advance.
> This is the last time I will tell you this before removing you from the
> list. Do not post
> these questions here.
>    Matt
>> David
>>   On Wed, Mar 24, 2010 at 12:09 PM, Satish Balay <balay at mcs.anl.gov>wrote:
>>> moving this discussion to petsc-maint. Not appropriate for petsc-dev
>>> satish
>>> On Wed, 24 Mar 2010, David sheehan wrote:
>>> > That was an old try.
>>> > My new try including all output information is the following.
>>> Everything is
>>> > OK except for "make test"  has one error.
>>> > I checked the library of HYPRE. All HYPRE libs have been created, but
>>> they
>>> > cannot be installed with PETSC libs.
>>> > And I manually copy all HYPRE libs into the directory of the
>>> final-installed
>>> > PETSC's libs, but "make test" still has
>>> > the same problem.
>>> > Please fix it, thanks.
>>> > David
>>> > -----------------------------------------------the final installed
>>> libs-------------------------------------------------------------------------------------------------
>>> > [ petsc-2.3.3-p15]$ ls /home/David/petsc233-p15/lib/linux-gnu-c-debug/
>>> > libpetsc.a         libpetscdm.a   libpetscmat.a   libpetscts.a
>>> > libpetsccontrib.a  libpetscksp.a  libpetscsnes.a  libpetscvec.a
>>> > ------------------------------------------------PETSC
>>> libs---------------------------------------------------------------------------------------------------
>>> > [ petsc-2.3.3-p15]$ ls lib/linux-gnu-c-debug/
>>> > --------------------------------------------------HYPRE
>>> externalpackages/hypre-2.0.0/linux-gnu-c-debug/lib/
>>> > libHYPRE.a                               libHYPRE_MatrixMatrix.a
>>> > libHYPRE_sstruct_ls.a
>>> > libHYPRE_DistributedMatrix.a             libHYPRE_multivector.a
>>> > libHYPRE_sstruct_mv.a
>>> > libHYPRE_DistributedMatrixPilutSolver.a  libHYPRE_ParaSails.a
>>> > libHYPRE_struct_ls.a
>>> > libHYPRE_Euclid.a                        libHYPRE_parcsr_block_mv.a
>>> > libHYPRE_struct_mv.a
>>> > libHYPRE_IJ_mv.a                         libHYPRE_parcsr_ls.a
>>> > libHYPRE_utilities.a
>>> > libHYPRE_krylov.a                        libHYPRE_parcsr_mv.a
>>> > libHYPRE_LSI.a                           libHYPRE_seq_mv.a
>>> ----------------------------------------configure------------------------------------------------------------------------------------------------------
>>> > [ petsc-2.3.3-p15]$ export PETSC_DIR=$PWD
>>> > [ petsc-2.3.3-p15]$  ./config/configure.py
>>> --prefix=/home/David/petsc233-p15
>>> > --with-cc=gcc --with-cxx=g++ --with-fc=ifort
>>> --with-mpi-dir=/opt/openmpi
>>> > --with-hypre=1 --download-hypre=ifneeded
>>> >              Configuring PETSc to compile on your system
>>> > TESTING: configureLibrary from
>>> > PETSc.packages.hypre(python/PETSc/packages/hypre.py:120)
>>> > using: --with-MPI-include="/opt/openmpi/include"
>>> > Compilers:
>>> >   C Compiler:         gcc  -fPIC -Wall -Wwrite-strings
>>> -Wno-strict-aliasing
>>> > -g3
>>> >   C++ Compiler:       g++  -Wall -Wwrite-strings -Wno-strict-aliasing
>>> -g
>>> > -fPIC
>>> >   Fortran Compiler:   ifort  -fPIC -g
>>> > Linkers:
>>> >   Shared linker:   gcc  -shared  -fPIC -Wall -Wwrite-strings
>>> > -Wno-strict-aliasing -g3
>>> >   Dynamic linker:   gcc  -shared  -fPIC -Wall -Wwrite-strings
>>> > PETSc:
>>> >   ** Before running "make" your PETSC_ARCH must be specified with:
>>> >   **  ** setenv PETSC_ARCH linux-gnu-c-debug (csh/tcsh)
>>> >   **  ** PETSC_ARCH=linux-gnu-c-debug; export PETSC_ARCH (sh/bash)
>>> >   PETSC_DIR: /home/David/petsc/petsc-2.3.3-p15
>>> >   ** Now build and test the libraries with "make all test"
>>> >   Clanguage: C
>>> >   PETSc shared libraries: disabled
>>> >   PETSc dynamic libraries: disabled
>>> >   Scalar type:real
>>> > MPI:
>>> >   Includes: ['/opt/openmpi/include']
>>> >   Library:  ['/opt/openmpi/lib/libmpi.a']
>>> > X11:
>>> >   Includes: ['-I/usr/X11R6/include']
>>> >   Library: ['-L/usr/X11R6/lib -lX11']
>>> > BLAS/LAPACK: -llapack -lblas
>>> > hypre:
>>> >   Includes:
>>> ['/home/David/petsc/petsc-2.3.3-p15/externalpackages/hypre-2.0.0/linux-gnu-c-debug/include']
>>> >   Library:
>>> ['/home/David/petsc/petsc-2.3.3-p15/externalpackages/hypre-2.0.0/linux-gnu-c-debug/lib/libHYPRE.a',
>>> > '-Wl,-rpath,/usr/lib/gcc/i386-redhat-linux/3.4.6',
>>> > '-Wl,-rpath,/usr/lib/gcc/i386-redhat-linux/3.4.6/../../..', '-lstdc++']
>>> > ---------------------------------------------------make
>>> install---------------------------------------------------------------------------------
>>> > Installing PETSc at /home/David/petsc233-p15
>>> > Shared libraries disabled
>>> > sh/bash: PETSC_DIR=/home/David/petsc233-p15; export PETSC_DIR
>>> > csh/tcsh: setenv PETSC_DIR /home/David/petsc233-p15
>>> > Then do make test to verify correct install
>>> test-------------------------------------------------------------------------------------
>>> > Running test examples to verify correct installation
>>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
>>> MPI
>>> > process
>>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
>>> MPI
>>> > processes
>>> > Possible error running Graphics examples
>>> src/snes/examples/tutorials/ex19 1
>>> > MPI process
>>> > See
>>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
>>> > lid velocity = 0.0016, prandtl # = 1, grashof # = 1
>>> > [0]PETSC ERROR: --------------------- Error Message
>>> > [0]PETSC ERROR: Error in external library!
>>> > [0]PETSC ERROR: Unable to open display on apmachine:0.0
>>> > .  Make sure your COMPUTE NODES are authorized to connect
>>> >     to this X server and either your DISPLAY variable
>>> >     is set or you use the -display name option
>>> > [0]PETSC ERROR:
>>> > [0]PETSC ERROR: Petsc Release Version 2.3.3, Patch 15, Tue Sep 23
>>> 10:02:49
>>> > CDT 2008 HG revision: 31306062cd1a6f6a2496fccb4878f485c9b91760
>>> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> > [0]PETSC ERROR: See docs/index.html for manual pages.
>>> > [0]PETSC ERROR:
>>> > [0]PETSC ERROR: ./ex19 on a linux-gnu named apmachine by David Wed Mar
>>> 24
>>> > 11:41:48 2010
>>> > [0]PETSC ERROR: Libraries linked from
>>> > [0]PETSC ERROR: Configure run at Wed Mar 24 11:21:40 2010
>>> > [0]PETSC ERROR: Configure options --prefix=/home/David/petsc233-p15
>>> > --with-hypre=1 --download-hypre=ifneeded --with-shared=0
>>> > [0]PETSC ERROR:
>>> > [0]PETSC ERROR: PetscDrawXGetDisplaySize_Private() line 618 in
>>> > src/sys/draw/impls/x/xops.c
>>> > [0]PETSC ERROR: PETSc unable to use X windows
>>> > proceeding without graphics
>>> > Number of Newton iterations = 2
>>> > Fortran example src/snes/examples/tutorials/ex5f run successfully with
>>> 1 MPI
>>> > process
>>> > Completed test examples
>>> > On Wed, Mar 24, 2010 at 9:35 AM, Satish Balay <balay at mcs.anl.gov>
>>> wrote:
>>> > > On Tue, 23 Mar 2010, David sheehan wrote:
>>> > > > I try openmpi, there are the following error,
>>> > > > ./configure --prefix=/home/David/petsc300p11_openmpi --with-cc=gcc
>>> > > > --with-cxx=g++ --with-fc=ifort --download-openmpi=1
>>> --download-hypre=1
>>> > > > TESTING: check from
>>> > > > config.libraries(config/BuildSystem/config/libraries.py:126)
>>> > > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see
>>> configure.log for
>>> > > > details):
>>> > > > Currently --download-openmpi option does not work with --prefix
>>> install.
>>> > > > Suggest installing OpenMPI separately, and then configuring PETSc
>>> with
>>> > > > --with-mpi-dir option.
>>> > > > How to fix it? thanks.
>>> > > configure already gave the answer to your question
>>> > > satish
>  What most experimenters take for granted before they begin their
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100324/69b82593/attachment.html>
