[petsc-dev] MatSetValuesStencil() and all that
mccomic at mcs.anl.gov
Mon Mar 22 10:00:49 CDT 2010
Barry,
I agree that an array of stencils makes sense, and at introducing each stencil we would have the user indicate the name of the model it is associated with. Then every call to MatSetValuesStencil would have an optional argument for the model name, or more likely we'd make a MatSetValuesStencilMP rather than overloading MatSetValuesStencil.
It will probably be striaghtforward to say where in the large matrix the new physics fits, but I don't think it's trivial to handle the indices for the off-diagonal blocks because the coupling could be arbitrarily complicated.
I'll take a look at this and see what I can do.
-Mike
----- Original Message -----
To: "Mike McCourt" <mccomic at mcs.anl.gov>, "Lois Curfman McInnes" <curfman at mcs.anl.gov>, "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
Sent: Friday, March 19, 2010 4:37:51 PM GMT -06:00 US/Canada Central
Subject: MatSetValuesStencil() and all that
Mike,
MatSetValuesStencil() does a simple mapping of the stencil values
to the local numbering and then calls MatSetValuesLocal().
To extend this for "multiphysics" is I think pretty
straightforward, the only difficulty will be getting all the indices
right.
Currently a single stencil is attached to the matrix with
MatSetStencil() what we will need to do is allow multiple stencils to
be attached with multiple calls. Then we can add another field to
MatStencil to indicate what "physics" you are putting values in
associated with. Then the mappings in MatSetValuesStencil() (and
blocked versions) need to be updated to properly handle the several
"physics".
You will also need another argument (or maybe more than 1?) to
MatSetStencil() to indicate where in the large matrix the new
"physics" fits.
To make the code simple I would make the mat->stencil field be an
array of, say, 5 and introduce a mat->stencilcnt field to keep track
of how many have been set so far. Then the new field in MatStencil
would be used in the mapping code to select which mat->stencil[] to
pull out.
Can you take a look at the code and see if it is feasible for you
to make these changes? Feel free to send email or come by my office
with questions.
Barry
