[petsc-dev] post 3.1 reorganization of PETSc DMMG code
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Mar 19 16:23:23 CDT 2010
   Now that the 3.1 repository has been cloned I'd like to start work
on the reorganization of PETSc to pull all the functionality of DMMG
into the SNES, PC and TS components. I want to do this because
1) the DMMG "solver" are not compossible with each other and other
solvers. For example, inside a PCFIELDSPLIT preconditioner I'd like to
use a multigrid solver on one component and I'd like the management of
that multigrid solver to be handled by something as simple as the DMMG.
2) the DMMG solvers cannot be used by TS
3) there is currently two ways to solve linear systems, with
KSPSolve() directly or with DMMGSolve(). One of my most fundamental
design principles is having two DIFFERENT ways of doing something is bad
4) DMMG very nicely handles a hierarchy grids and sets everything in
the PCMG structure automatically for you, but it does not handle, for
example, setting up a PCFIELDSPLIT preconditioner
Thus I propose we completely eliminate the DMMG code and instead have
each TS, SNES, PC object (for KSP objects this is pretty much
irrelevant) be able to take a DM and "fill themselves up" by using
appropriate information from the DM; just as the DMMG "fills up the
PCMG" with the correct interpolation/restriction, coarser grid
matrices etc. Thus much of the current DMMG code will end up inside
the PCMG.  Similarly PCFIELDSPLIT will be able to take its DM and fill
up much of itself.
To accomplish this we will need the DM to be a richer object.
Currently a DM can give coarsened versions of itself (and refined
versions) we need to add a way to have it give "subphysics" versions
of itself. For example if we are solving a 2-component PDE and have an
associated DM, then we would like to be able to get a new DM
associated with a single component. For example, say we wish to use
PCFIELDSPLIT with multigrid on the first component and ILU on the
second. The PCFIELDSPLIT would have its two PCs and pass down to them
the sub DM. Now the multigrid subPC would use the DM it is given to
coarsen and create the hierarchy of grids and interpolations etc.
Currently when Jed codes this he has to manage that himself or do some
ugly crud where he wraps a DMMG inside that fieldsplit. If we do this
right it could be extremely powerful.
Tasks
(1) merge DMMG linear into PCMG. I think this is straightforward and
doesn't have any conceptual challenges at all
(2) merge DMMG nonlinear in SNES. With (1) done this is pretty much
done except for the conceptual issue of how to handle grid sequencing?
This solves the multigrid problem.
(3) introduce into DM the ability to "get subphysics" DM. Here the
conceptual question is how to indicate them. Do we introduce the idea
of having each DM as having N "fields" and then to be able to request
"field 1 and 2" etc? PCFIELDSPLIT has this concept with
PCFieldSplitSetFields(). This is easy enough to implement but I don't
like it. The reason I don't like it is that we already have the
concept of IS that is used to indicate subsets of things; I HATE to
have two different ways of doing something. We also have
PCFieldSplitSetIS() which is "generalization" of
PCFieldSplitSetFields(), if I wasn't so lazy when I added
PCFieldSplitSetIS() I would have immediately removed
PCFieldSplitSetFields(). So I would like to have
DMGetSubDM(DM,MPI_Comm,IS,DM*). For DA with suitable stride and block
stride IS this is easily done and makes sense, an arbitrary IS would,
of course, have to generate an error.  For DMCOMPOSITE providing sub
IS's would be cumbersome and not intuitive at all. So perhaps we do
need both types of getters. (Side note, if we introduce some builtins
like IS_FIELD_1, IS_FIELD_2 then perhaps we could have one interface
that was reasonably painless for the simple cases of fields but is
general? I'll think about this.)
   Suggestions, comments improvements?
    Barry
