[petsc-dev] ASM request
Jed Brown
jed at 59A2.org
Tue Mar 16 13:35:38 CDT 2010
On Tue, 16 Mar 2010 14:12:03 -0400, Matthew Knepley <knepley at gmail.com> wrote:
> You have a preconditioner which is ASM, but with a LOT of small
> blocks. You do not save very much by discarding one big block, but if
> you only ever form each small block, you get a lot of savings.
Unless I misunderstand you, this means that you'll be refactoring each
block on every Krylov iteration. I realize it's a bit less memory, but
that's going to be pretty painful.
Jed
