[petsc-dev] ASM request
Matthew Knepley
knepley at gmail.com
Tue Mar 16 13:12:03 CDT 2010
On Tue, Mar 16, 2010 at 1:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 16, 2010, at 11:28 AM, Matthew Knepley wrote:
> There is a request to make a more memory efficient version of ASM for
>> running
>> very large system of equations. They are using LU on small diagonal
>> blocks, and
>> have asked that the blocks be factored, applied, and discarded, rather
>> than being
>> saved for all iterations. Does anyone think this is easy in the current
>> ASM code?
>> Have an alternate proposal?
> I need a better understanding. Is it that after the KSPSolve() they want
> more memory available for their own use that they will allocate after the
> KSPSolve and free before the next PCSetUp()? If this is what they want then
> I think it is trivial to implement, but we will need an API so that they can
> say when they are done with the solves and want us to free up the memory.
> Normally ASM is memory intense because
> 1) it makes copies of the matrix subblocks
> 2) it factors those subblocks into additional memory.
> If you use ILU(0) and the inplace option then it only needs one copy of the
> blocks instead of the two.
Yes, told them that so 1/2 off memory. I guess the easiest way to give them
this might be to put a shell matrix in the KSP
that sucks out the submatrix, factors it in place, applies it, and discards
it.
Here is the motivation:
You have a preconditioner which is ASM, but with a LOT of small blocks.
You do not save very much by discarding one
big block, but if you only ever form each small block, you get a lot of
savings.
Matt
> Barry
>> Matt
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100316/b7f21312/attachment.html>
