[petsc-dev] petsc.cs.iit.edu flakey
Satish Balay
balay at mcs.anl.gov
Wed Mar 3 18:50:39 CST 2010
http access is also now restored. Let me know if you encounter
any problems.
thanks,
Satish
On Wed, 3 Mar 2010, Satish Balay wrote:
> As a followup: the machine is now rebuilt - and the accounts, data
> restored.
> push/pull from ssh should work now.
> pull/browse from http is yet to be restored.
> Satish
> > Just a headsup..
> > petsc.cs.iit.edu is having disk errors and is being flakey. [unable to
> > reboot remotely]. So pushs/pulls might not work.
> > It will take some time to manually reboot it [and see if it stays
> > stable]. I'll followup when I have additional info.
> > Satish
