[petsc-dev] __SDIR__ as string or not
Barry Smith
bsmith at mcs.anl.gov
Tue Mar 2 16:45:17 CST 2010
Well Lisandro sent me down this path, so he can fix it.
Barry
On Mar 2, 2010, at 4:34 PM, Jed Brown wrote:
> On Wed, 24 Feb 2010 16:16:43 -0600, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> Lisandro suggested changing the model to use -D__INSDIR__=directory
>> with no quotes and then in petscerror.h have
>> #define PetscStringize(a) #a
>> #define __SDIR__ PetscStringize(__INSDIR__)
> Did you notice that all the error messages read like this now?
> [0]PETSC ERROR: ISSetPermutation() line 141 in __INSDIR__index.c
> Quoting from C99 6.10.3.4 Rescanning and further replacement:
> 1 After all parameters in the replacement list have been
> substituted and # and ##
> processing has taken place, all placemarker preprocessing tokens
> are removed. Then, the
> resulting preprocessing token sequence is rescanned, along with
> all subsequent
> preprocessing tokens of the source file, for more macro names to
> replace.
> As far as I know, there is no way to get the preprocessor to stringize
> the expansion of __INSDIR__.
> Note that a possible alternative to __SDIR__ is to send the full path
> name to the compiler, as in `pwd`/source, in which case __FILE__ would
> have the full path.
> Jed
