[petsc-dev] configuration crash
Satish Balay
balay at mcs.anl.gov
Wed Jul 28 16:34:51 CDT 2010
Note:
'--with-shared --with-dynamic' are now '--with-shared-libraries --with-dynamic-loading'
And most folks don't need --with-dynamic-loading.
Satish
On Wed, 28 Jul 2010, Wesley Smith wrote:
> Hi,
> I'm trying to build petsc-dev. I've just downloaded it form the repo
> a couple of days ago. When I run:
> ./configure --with-cc=gcc --with-clanguage=cxx --download-boost
> --with-fc=0 --download-parmetis --with-shared --with-dynamic
> --download-mpich --with-sieve --with-cuda=0
> I get:
> Configuring PETSc to compile on your system
> TESTING: checkCUDAPreprocessor from
> config.setCompilers(config/BuildSystem/config/setCompilers.py:531)
> CONFIGURATION CRASH (Please send configure.log to
> petsc-maint at mcs.anl.gov)
> This is what the bottom of the log says
> 'Configure' object has no attribute 'CUDACC' File "./configure", line
> 270, in petsc_configure
> framework.configure(out = sys.stdout)
> File "/Users/wesleysmith/Documents/projects/toposynth/PetSc/petsc-dev/config/BuildSystem/config/framework.py",
> line 946, in configure
> child.configure()
> File "/Users/wesleysmith/Documents/projects/toposynth/PetSc/petsc-dev/config/BuildSystem/config/setCompilers.py",
> line 1384, in configure
> self.executeTest(self.checkCUDAPreprocessor)
> File "/Users/wesleysmith/Documents/projects/toposynth/PetSc/petsc-dev/config/BuildSystem/config/base.py",
> line 97, in executeTest
> ret = apply(test, args,kargs)
> line 533, in checkCUDAPreprocessor
> for compiler in self.generateCUDAPreprocessorGuesses():
> line 528, in generateCUDAPreprocessorGuesses
> yield self.CUDACC+' -E'
> I was hoping --with-cuda=0 would prevent it from checking CUDA. I
> don't have CUDA on my system, so I can't give a value for CUDACC that
> would make sense and if I provide something random it still crashes.
> How can I circumvent this check to continue with the build process?
> thanks,
> wes
