[petsc-dev] CFLAGS / LDFLAGS and cxx error
Barry Smith
bsmith at mcs.anl.gov
Wed Jul 28 13:30:52 CDT 2010
On Jul 28, 2010, at 1:12 PM, Wesley Smith wrote:
> On Wed, Jul 28, 2010 at 11:10 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> You are passing the CFLAGS="-arch i386" to C but not g++ hence g++ is using the 64 bit. You need to set CXXFLAGS also to use 32 bit.
> yes, but why would it not be able to find any CXX compiler when
> setting those flags?
If you look at the configure.log in detail you can see why. The g++ test works,. but then it does a test to see if the g++ and gcc compilers can be used together this fails because they are built with different arches.
Barry
sh: g++ -c -o conftest.o conftest.cc
Executing: g++ -c -o conftest.o conftest.cc
Executing: g++ -o conftest -arch i386 conftest.o
sh:
Possible ERROR while running linker: ld: warning: in conftest.o, file was built for unsupported file format which is not the architecture being linked (i386)
Undefined symbols:
"_main", referenced from:
start in crt1.10.6.o
ld: symbol(s) not found
