[petsc-dev] [petsc-maint #50087] Re: why does PETSc BuildSystem hate me?
Aron Ahmadia
aja2111 at columbia.edu
Tue Jul 27 03:01:28 CDT 2010
Just another note. The reason I use LDFLAGS by default is because
./configure help (as generated by autoconf 2.59) does not mention
LIBS..
<typical configure help output>
Some influential environment variables:
CC C compiler command
CFLAGS C compiler flags
LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
nonstandard directory <lib dir>
CPPFLAGS C/C++ preprocessor flags, e.g. -I<include dir> if you have
headers in a nonstandard directory <include dir>
CPP C preprocessor
However, if you actually set the environment variables, trial and
error reveals that although LDLIBS is ignored by configure, LIBS and
LDFLAGS are respected.
I guess that's another confirmation for the use of LIBS/LDFLAGS, but
I'd like to note this inconsistency in their documentation:
http://www.gnu.org/software/hello/manual/autoconf/Preset-Output-Variables.html
"LDFLAGS can be set from the environment according to the manual,
whereas LIBS defaults to empty."
A recent autoconf seems to play a little more correctly:
LIBS libraries to pass to the linker, e.g. -l<library>
CPPFLAGS (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
you have headers in a nonstandard directory <include dir>
CPP C preprocessor
CXX C++ compiler command
CXXFLAGS C++ compiler flags
CXXCPP C++ preprocessor
F77 Fortran 77 compiler command
FFLAGS Fortran 77 compiler flags
FC Fortran compiler command
FCFLAGS Fortran compiler flags
Hope this was useful/enlightening.
Aron
On Tue, Jul 27, 2010 at 2:48 AM, Satish Balay <petsc-maint at mcs.anl.gov> wrote:
> Both MPI_DIR and LDFLAGS added now.
> Satish
> On Mon, 26 Jul 2010, Barry Smith wrote:
>> Satish,
>> Please add that one as well. MPI_DIR
>> Barry
>> On Jul 26, 2010, at 12:55 PM, Lisandro Dalcin wrote:
>> > On 26 July 2010 14:45, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> >> Satish,
>> >> It is missing Aron's favorite. Could you please add it LDFLAGS
>> >> I was expecting it up in config/configure.py before anything else? Won't that be a better place for it?
>> > Just a week ago, I had trouble to build PETSc with ML. The reason was
>> > a stale MPI_DIR environ var I had in my .bashrc.
>> > Lisandro Dalcin
>> > CIMEC (INTEC/CONICET-UNL)
>> > Predio CONICET-Santa Fe
>> > Colectora RN 168 Km 472, Paraje El Pozo
>> > Tel: +54-342-4511594 (ext 1011)
>> > Tel/Fax: +54-342-4511169
